1990 Pontiac Transport Engine dies after running 10-15 minu
1990 PONTIAC TRANSPORT
13,000 MILES • 6 CYL • FWD • AUTOMATIC
POPPA52
My 1990 Transport will run for 10-15 minutes, then die. A mechanic friend suggested the ignition module?, that thing under the distributor cap. That wasn't it. Then new coil....that wasn't it. Then, it just had to be the fuel pump and filter....that wasn't it. Still kept doing the same thing after each attempted fix. Any other ideas? We are fresh out of ideas. Thank you in advance.
Oct 25, 2009 at 10:25 PM
Hi poppa52 and TY for the donation
My 1990 Transport will run for 10-15 minutes, then die something has to give when it dies immediately do below below and tell me what's missing
The mechanic is throwing parts at it and its costing you this is not the right approach
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 26, 2009 at 12:21 AM
