1996 Pontiac Transport Blowing fuses
1996 PONTIAC TRANSPORT
124,274 MILES • 6 CYL • FWD • AUTOMATIC
CARPET_LIQUER
  • 4 POSTS
My wifes van keeps blowing HTR/AC fuses. I replace the fuse & 10 minutes of driving later...POP!!! I thought it was the relay and replaced it. It lasted a week and started blowing fuses again. I replaced the blower motor...but its still doing it. I have a Haynes manual but of course there isn't a wiring diagram for the climate system...go figure!!!
The resistor looks in good shape...is there something else using the same fuse? Maybe another component is faulty.
Nov 15, 2008 at 1:20 PM
JAMES W.
  • 2,394 POSTS
What size fuse is blowing? It is supposed to be a 20A according to the diagram. If it is blowing and you have or have access to a fax, I'll ship you a diagram. Normally I could attach it to this posting, but for some reason, it won't let me. Please advise, Jim.
Nov 15, 2008 at 2:02 PM
CARPET_LIQUER
  • 4 POSTS
It was a 25...but I even tried a 30amp. Still blows.
I don't have a fax machine.
Can you email it to [email protected] ?
That would be a huge help.
Thanks
Nov 15, 2008 at 7:16 PM
JAMES W.
  • 2,394 POSTS
Sorry it took so long to get back to you. My computer has been down. $1500.00 later, I'm back on line. Anyway, a couple of questions. Do you have an auxiliary blower system in the rear? When the fuse is out, is anything other than the blower not working, ie cigar lighter, rear blower or aftermarket equipment? Please advise.
Dec 2, 2008 at 12:50 AM
CARPET_LIQUER
  • 4 POSTS
Nothing that I've noticed. The ABS light is always on, the rear blower works fine. I was thinking I might run a couple of wires from the rear blower plug to the front blower motor, then just use the rear controls for the front fan.
Could it be the front speed switch?
Dec 3, 2008 at 4:00 PM
JAMES W.
  • 2,394 POSTS
Under the dash on the duct work there should be a resistor block that controls the blower motor speeds. The inner part of this block has several resistance coils for the various speeds. If any of these coils are touching, it will cause the problem you are having. Let me know what you find.
Dec 3, 2008 at 6:54 PM
CARPET_LIQUER
  • 4 POSTS
The resistor block is under the hood attached to the blower housing and they all look fine.
Jun 7, 2009 at 9:02 AM
