Possible bad accelerator pedal position sensor?
2007 CHEVROLET MALIBU
162,000 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
KRISTINAWHITE09
  • 44 POSTS
I had my throttle body cleaned recently (one person was pushing on gas pedal while the other cleaned throttle body with throttle body cleaner). Right after that, I drove it and noticed the idle was all over the place and the gas pedal would stay down (like it was in cruise control). I had to have a used transmission put in (bad idea to take it to the dealership - pretty sure they burned out 1st gear) but I'm worried that I'll still have the idle/gas pedal problem. I'm just wondering if this would be a bad accelerator pedal position sensor (I don't have a TPS) due to the gas pedal being pressed down so long while the TB was being cleaned. I ordered an APPS but my car is still at the transmission shop. They said they'd try to diagnose my issue after replacing the transmission but wanted to get a good grasp on what the likely issue is.
Aug 24, 2014 at 3:38 PM
HMAC300
  • 48,601 POSTS
reclean the throttle plate on both sides an diac hole and if it still does it check for a vacuum leak like a line broken or left off
Aug 24, 2014 at 3:49 PM
KRISTINAWHITE09
  • 44 POSTS
Thanks for the suggestions! It ended up (apparently) just being my transmission. I'm not having any of the same issues now since they replaced mine with a used one.
Aug 26, 2014 at 7:53 AM
