Power steering fluid replacement instructions
1996 CHRYSLER TOWN AND COUNTRY
225,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
MASCARENAS92
About a week ago my powersteering pump stoped working. The fluid is real thick. How do i drain this all the way to pump to replace it?
Jan 21, 2021 at 4:12 AM
Good morning,
I attached a picture of where you have to remove the return line from the pump to drain the fluid. When you disconnect it, put the hose in a bucket. Cap the open line on the pump with a rubber line to prevent leaking.
https://www.2carpros.com/articles/power-steering-fluid-flush
https://www.2carpros.com/articles/power-steering-problems
Then start the motor and add fluid as it runs into the bucket to flush the system of all the old fluid. Run about a gallon on fluid through the system before turning it off. Then hook the system back up and top off the system.
Jan 21, 2021 at 4:35 AM
