Power window, door locks and mirrors not working
1997 HONDA DEL SOL
68,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
KINSELJR
  • 4 POSTS
My driver's window would go down but not up. Power door locks and key fob would not work. Power mirrors would not work. After throwing parts at it. : ( Driver door master switch, power window control module I took it to a mechanic who found the problem to be the wiring to the driver's door in the door jamb. He had to take the door off and clean up the wiring connections and now it is all working great with the original driver's master switch and window control module.
Dec 23, 2017 at 9:38 AM
That is good information im sure will help our site visitors. Please feel free to help out whenever you are on the site :)
Dec 24, 2017 at 11:03 AM
KINSELJR
  • 4 POSTS
You are welcome Ken. I was surprised they had to take the door off and wish I could have been there to see what they did! Merry Christmas!
Dec 24, 2017 at 2:43 PM
STEVE W.
  • 15,116 POSTS
Most likely item would be that a wire or wires in the door harness failed and they pulled the door to have better access to the wires to repair/replace the failed sections. Small car, light door would be much easier to work on it on a bench than kneeling next to the car to do the repairs.
Dec 25, 2017 at 10:19 AM
KINSELJR
  • 4 POSTS
I can relate to that, LOL! Thanks, that makes sense. So happy to have the Del Sol back to 100%!
Dec 25, 2017 at 12:29 PM
STEVE W.
  • 15,116 POSTS
Yeah, there are times when I will tear off half the vehicle just to get to a part so I can deal with it on the bench. So much easier than trying to twist yourself in knots to work on it where it is. For a repair like that I would have either pulled the door or put it on the mid rise lift. It is like working on many full sized trucks. I will pull the front tires and set them down with blocks under the suspension so I can work at a comfortable height.
Dec 26, 2017 at 5:30 AM
