Push-rods
2003 PONTIAC GRAND AM
200,000 MILES • 6 CYL • FWD • AUTOMATIC
BROKENEGGS
  • 198 POSTS
All push rods have been removed. I need to put them back in but do not know where they go. There are two sizes one is shorter than the other. I was told one is for exhaust an other for intake, but I do not know which one goes where. (Help)
Sep 30, 2017 at 6:13 AM
STEVE W.
  • 15,113 POSTS
Short ones are for intake and long are for exhaust. But, if you do not know which ones came from where and the rockers have been moved around, do not be surprised if you see a lot of wear between the parts.
Coat them with a good glob of break in lube and hope they do not fail.
Sep 30, 2017 at 12:09 PM
BROKENEGGS
  • 198 POSTS
Do all the long one's go in the back slots and all the short one's go in the front slots ?
Oct 2, 2017 at 6:31 AM
Yes, please send a picture of what you are talking about so we can see whats going on if you can
Best, Ken
Oct 2, 2017 at 1:49 PM
BROKENEGGS
  • 198 POSTS
I managed to get this part done, But now I have another problem, It is running rough and blowing white smoke, it will not go past 4 rpm's with out smoothing down, What is going on ?
Oct 2, 2017 at 1:56 PM
STEVE W.
  • 15,113 POSTS
Sounds like a blown head gasket or water leaking into the engine. That is what causes white smoke. What was it originally taken apart for?
Oct 2, 2017 at 3:18 PM
BROKENEGGS
  • 198 POSTS
A broken intake valve push rod. But after running for awhile it has quit smoking but it is still idling rough but when I give it a little gas it runs fine as long as I do not take it up to 4 rpm's If I take it up to 4 rpm's it smothers down. I noticed it was low on water so I added a gallon jug but I noticed it is starting to run hot after running just for a minute are two it never did this before. Why is it Smothering down and running hot ?
Oct 3, 2017 at 8:19 AM
BROKENEGGS
  • 198 POSTS
Like I say there is no white smoke anymore, But even if you can't see it their is a o strong a odor of Carbon Monoxide coming from it that you can't stand to stay around it and every once in awhile a tinging sound.
Oct 4, 2017 at 11:16 AM
Smothering down is normal in neutral the computer will not allow the engine to rev above 4 to help the engine to not be damaged.
The rough idle I feel is the concern. Lets go back to basics and make sure the compression is good all around.
Please let us know what you find
Oct 4, 2017 at 12:39 PM
BROKENEGGS
  • 198 POSTS
Thanks for this. Could the spark plugs cause this same problem, I have no idea when they were last changed. It has always cranked and ran well, so I gave them no thought.
Oct 5, 2017 at 8:10 AM
STEVE W.
  • 15,113 POSTS
Plugs could cause rough running. High fume level sounds like the convertor is getting hit with a lot of fuel.
Oct 5, 2017 at 6:58 PM
BROKENEGGS
  • 198 POSTS
What is causing to much gas to get to converter and what do I need to do to fix this ?
Oct 6, 2017 at 7:48 AM
BROKENEGGS
  • 198 POSTS
I have noticed that in the related section that their are a lot of people having problems with their push rods. Is this a Pontiac issue ?
Oct 6, 2017 at 7:53 AM
STEVE W.
  • 15,113 POSTS
The engine rough running is why you are getting the smell. It's from misfiring in the cylinders dumping extra fuel into the converter. Once that is repaired it should be better.
Oct 6, 2017 at 8:11 AM
BROKENEGGS
  • 198 POSTS
Thanks for all your help. I had a test ran today and it shows a bad MAP (Manifold Absolute Pressure ) Sensor. I purchased a new one, When I have the old one replaced with this new one I will let you know if this does the trick..
Oct 10, 2017 at 4:59 PM
Oct 11, 2017 at 10:15 AM
BROKENEGGS
  • 198 POSTS
Nothing Happened, there is no difference in the new one from the old one. there was a mechanic in the parts house and he took time enough to do a little checking for me, and he says he believes I have a vacuum leak some where.
Oct 11, 2017 at 2:02 PM
STEVE W.
  • 15,113 POSTS
Vacuum is what controls the MAP so if there is a leak it can cause the MAP readings to be wrong. Easy way to look for a vacuum leak is to GENTLY spray some starting fluid along the hoses and intake and listen for the engine to speed up. Just don't spray a lot at a time, you don't want to have it running along places. It could "find" a leak if it runs to a spot you haven't sprayed yet, then you think the leak is where you just sprayed.
Another way is to spray water around and listen for it to be sucked in, this way works fine as long as you don't drown the engine. An easy test bottle for this is a soda/water bottle with a small hole in the top. Use it like a squirt gun to spray things.
Oct 11, 2017 at 2:12 PM
BROKENEGGS
  • 198 POSTS
The hose that plugs into back of the motor and the other end plugs into top of large hose that goes to air filter has a bad fitting that goes into back of motor and keeps coming out of hole, so I took it off just to see what would happen and there was no change in the rough way it was running.
Oct 11, 2017 at 7:39 PM
STEVE W.
  • 15,113 POSTS
There wouldn't be a change if it leaks and you remove it. That just makes the leak worse.
Oct 12, 2017 at 1:41 AM
BROKENEGGS
  • 198 POSTS
How can I send you a pic of this hose ?
Oct 12, 2017 at 8:48 AM
Take a pic with your phone and upload it to the site here "add image or video" link below the text box
Oct 12, 2017 at 10:40 AM
BROKENEGGS
  • 198 POSTS
This is no working for me.
Oct 12, 2017 at 11:49 AM
BROKENEGGS
  • 198 POSTS
I tried o send a pic to you but I just can't get it to work. But I was able to share it on my FB timeline. You can see a pic of it there. Just go to FB and type my account name ( Richard Whitman ) and you will find the pic there. I can't find this thing at any parts stores here in Houston, Texas. Please let me know what the proper name of it is, Because I am going to have to order it from dealer or factory and I can't order it if I don't know the name of what I am trying to order. Again Thanks for everything.
Oct 12, 2017 at 1:56 PM
STEVE W.
  • 15,113 POSTS
Most likely item number 3 which is a fresh air hose for the PCV system.
Oct 12, 2017 at 6:00 PM
BROKENEGGS
  • 198 POSTS
please check out pic on Facebook. Open Facebook at top left type in Richard Whitman and check out the picture of item I need. If you know what it is called please let me know.
Oct 12, 2017 at 6:21 PM
STEVE W.
  • 15,113 POSTS
That picture IS yours from facebook. It is item 3 in the left hand image.
Oct 12, 2017 at 7:23 PM
BROKENEGGS
  • 198 POSTS
COULD THIS BE THE CAUSE OF ROUGH RUNNING, Do you think when I replace this it will solve my problem?
Oct 13, 2017 at 12:44 PM
STEVE W.
  • 15,113 POSTS
If it is broken or loose it is a vacuum leak. It is the tube that let's fresh air get into the engine so the PCV system can work.
Oct 13, 2017 at 3:50 PM
BROKENEGGS
  • 198 POSTS
Finely found a way.
Oct 13, 2017 at 4:12 PM
