Security lockout, rack and pinion, starter?
2014 CHEVROLET CAMARO
120,000 MILES • 6.2L • V8 • 2WD • AUTOMATIC
AMERCHANT031
  • 8 POSTS
The jack slipped and broke the rack and pinion, and the car couldn’t start anymore making a clicking sound like the starter is bad. The starter still looks good. I replaced the rack and pinion but still had the same problem.
Sep 9, 2024 at 3:00 PM
Probably broke the starter housing, which is difficult to see, can you upload a short video of the noise or what is it doing so I can see? If the starter solenoid is getting power in the crank position the starter is bad.
This guide can help us:
https://www.2carpros.com/articles/starter-not-working-repair
Here is the starter wiring diagrams so you can see how the system works as well. Please go over this video as well. Can I ask if the security light is flashing?
https://youtu.be/6YRW8fyNudY?si=hFtpKkNi2siiVc83
Here is how to change out the starter motor, start by disconnecting the battery. Check out the images (below). Please let us know what happens.
Sep 9, 2024 at 3:50 PM
AMERCHANT031
  • 8 POSTS
Yes, the security light is flashing.
Sep 9, 2024 at 4:19 PM
AMERCHANT031
  • 8 POSTS
Sep 10, 2024 at 8:55 AM
Thanks for the video, are you leaving the key on when the dash lights go out? I can't tell what the key is doing? Nor could I see the security light.
Sep 10, 2024 at 9:37 AM
AMERCHANT031
  • 8 POSTS
Yes, I’m leaving the key on when the dash light goes out. When the jack slipped the alarm did go off multiple times I forgot to add.
Sep 10, 2024 at 9:51 AM
There must be some kind of computer damage, we need to do a CAN scan to see what codes come up, this is not a regulator engine or drivetrain scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
I have seen the human interface module go out in these cars FYI. Please go over this guide and get back to us.
Sep 10, 2024 at 10:20 AM
AMERCHANT031
  • 8 POSTS
The jack slipped and broke the rack and pinion. The car alarm started going off multiple times. The car will not start anymore. it makes no noise when you turn the key. I replaced the rack and pinion but it’s still the same problem.
Sep 10, 2024 at 10:49 AM (Merged)
Let me know after you do the CAN scan.
Sep 10, 2024 at 10:50 AM
AMERCHANT031
  • 8 POSTS
I did the can scan and it says no communicating with the ECM.
Sep 10, 2024 at 2:51 PM
Hmm, it sounds like the battery could be bad, I would remove it and take it to the auto parts store for testing. Check out the images (below). Please let us know what happens.
Sep 10, 2024 at 4:58 PM
AMERCHANT031
  • 8 POSTS
The battery is new no older than 3 weeks but I tested it it’s good the starters good also.
Sep 10, 2024 at 5:03 PM
Let's try a hard system reboot, this guide can help you:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Also, have you checked all of the fuses? This guide can help, and I have included the fuse locations, please check the fuses with the ignition system on. Check out the images (below). Please let us know what happens.
Sep 11, 2024 at 10:45 AM
