Ignition on center locking works radio doesn't. Key off center locking doesn't work.
May 31, 2023 at 10:06 PM
CERTIFIED EXPERT
Let's run the codes to confirm the BCM failure. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon here is a video to show you how.
Here is how to change the BCM out in case you need it. Check out the images (below). Please let us know what happens. You can get a preprogrammed unit by searching Google or Ebay.
