Radio & Voice Command issues
2008 MERCEDES BENZ S550
56,000 MILES • 5.3L • V8 • RWD • AUTOMATIC
ECLASS VEGAS
Hello, I have a 2008 S550, here is the problem. my sound system has a constant clicking noise or popping when using the Radio, When using the phone I can hear the caller, they can not hear me. and my Sirius/XM will not pick up or go to preview channels. My embrace cannot locate the car and when I press the (i) button nothing happens. when I try to go to the audio menu it will not stay on what I select it jumps in and out of that screen.
Mar 27, 2017 at 10:23 AM
STEVE W.
  • 15,113 POSTS
Sounds like you need to replace the infotainment unit (what used to be the radio). Being it's a Mercedes and 2008 this isn't a simple remove and replace as the unit isn't just a radio. It is VIN tied to the vehicle and controls and stores settings for many other systems. A dealer would be your best bet for replacement because there are at least 2 modules that have to be reprogrammed to allow a replacement unit to operate and even for the car to run after replacement. They will have the proper tools to do the reprogramming and testing of the new system.
Mar 28, 2017 at 7:46 PM
ECLASS VEGAS
Hello, I have a 2008 S550, here is the problem. My sound system has a constant noise or popping when using the Radio, When using the phone I can hear the caller, they can not hear me. And my Sirius/XM will not pick up or go to preview channels. My embrace cannot locate the car and when I press the (i) button nothing happens. When I try to go to the audio menu it will not stay on what I select it jumps in and out of that screen. I put a DVD movie in I can see the picture but no audio.
Apr 5, 2017 at 12:46 AM
UEGRAD85
I have an S550 2009 with similar issues. Noise, controller is a erratic (won’t stay in menu). Also my telephone mic is not working, I can hear but the other person cannot hear me.
Did you have any luck finding a resolution?
Feb 19, 2019 at 2:58 PM
It sounds like you have a command controller that is out or fuse # 122 in the rear SAM or #51 in the front SAM. Here is a guide to help you check and the fuse box locations as well as the wiring diagrams so you can see how the command system works:
Feb 19, 2019 at 5:35 PM
