Random misfire/oil on spark plug, codes P0301 and P0300
2005 CHEVROLET TRAILBLAZER
210,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
RICKYSH11
  • 75 POSTS
I started getting some really bad misfiring on the way to work one morning. I used my code reader and picked up a P0301 and then P0300. So I went and got a spark plug to change the one on cylinder one. After doing so the engine still ran rough. I decided to change all of them and coming onto the third cylinder I found oil in the well. The plug was fairly saturated with oil. This was the only one like it. After reading about possible causes, it seems that I will have to remove the valve cover to replace a gasket for the spark plugs. Is there any information as to what exactly would need to be done? I usually do most of the work on my vehicles but do not really know the starting point for this job.
Jun 9, 2018 at 9:24 AM
It sounds like the valve cover gasket is causing the problem. Here is a guide to show you what you are in for when doing the job and diagrams with instruction below on how it is done on your car:
https://www.2carpros.com/articles/replace-valve-cover-gasket
After you are done I would check the MAP sensor which can be off a little causing a random misfire code.
Jun 11, 2018 at 11:50 AM
RICKYSH11
  • 75 POSTS
Thanks, that was very helpful. I finally finished the job of replacing the gasket and I changed all the plugs as well. After doing so I started it up and still had some really rough idling along. I have not checked the MAP yet but will do so next. I did notice however the battery may be in need of replacing it is a few years old and is not the best quality and the alternator may need replacing as well it is original to the vehicle, I am sure if that would contribute to the issue or not.
Jun 14, 2018 at 9:26 PM
Oh yes, the battery and alternator must be in good condition because the ignition system depends on a clean (no turbulence) voltage supply. I would replace them and clean the battery cables. Make sure you use OEM spark plugs and coils also can you run the codes again?
and
Jun 15, 2018 at 10:25 AM
RICKYSH11
  • 75 POSTS
Hey thanks again. I ended up finding the issue to be the ignition coil on cylinder one. I checked the battery and the alternator and ran the codes again, both were good. I had gotten a code for P0301 and since I already changed the plug I tried a coil and the misfire is gone and so far it is running normally.
Jun 15, 2018 at 4:47 PM
Nice work. It sounds like a coil issue. Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jun 16, 2018 at 11:13 AM
