Hi, I actually drive a rb20det swapped s13 to clear things up.
My rb20det is sucky when it's cold started, and it runs completely smooth when it has warmed up a little. When it's cold it idles super low, i can't rev above 3,500 RPM's without it popping or misfiring constantly and i can't go over RPM's in neutral. When i do that in gear it does the same thing but it violently shakes the car back and forth.
I have changed the coil packs to splitfire’s, i have changed the spark plugs more than enough times, my MAF is new and clean, my grounds are good, and i am having no vacuum leaks to my knowledge. The only thing i don't have is an IACV-AAC, seems the previous owner disconnected it or broke it somehow so i have one ordered. i wonder if it will fix my problem. Any help is welcome thanks.
Nov 15, 2020 at 2:14 PM
