Rear A/C fan not working, front works fine?
2005 FORD FREESTYLE
157,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
TEXASFREESTYLE
Front A/C and heat work like a charm, when I try to turn on rear fan manually, I can hear a click with no blower response. I've checked the fuses under dash and fuses and relays under hood with no luck.
Aug 4, 2024 at 6:35 PM
The first thing we need to do is check the fuse #f1-32 on the left side of the engine compartment which runs the rear blower motor. Here is a guide to help and the fuse location below:
If the fuse is okay, here is a guide to help test the blower motor which has probably gone bad:
https://www.2carpros.com/articles/how-to-test-an-automotive-hvac-system-blower-fan-motor-a-detailed
Aug 5, 2024 at 9:46 AM
