There are several options for the differential.
This is another one:
Rear Axle Shaft Replacement (8.6, 9.5/9.5LD Inch Axles)
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
2. Remove the tire and wheel assembly.
3. Remove the brake caliper.
4. Remove the rear cover and the gasket.
5. Remove the pinion shaft locking bolt.
6. On axles without a locking differential, remove the pinion shaft.
7. On axles with a locking differential, remove the shaft part way. Rotate the case until the pinion shaft touches the housing.
8. On axles with a locking differential, use a screwdriver, or a similar tool, in order to enter the differential case and rotate the lock (1) until the lock aligns with the thrust block (2).
9. Push the flange of the axle shaft (1) toward the differential.
10. Remove the C-lock (4) from the button end of the axle shaft (1).
11. Remove the axle shaft (1) from the housing (5).
Important: When removing the axle shaft, do not rotate the shaft. Rotating the shaft will misalign the gears. Misaligning the gears will make the assembly difficult.
Nov 25, 2020 at 11:01 AM
