Rear heater control valve?
1993 FORD E-SERIES VAN
125,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
ROBERT GIVENS
  • 5 POSTS
When replacing the rear heater control valve on a 1993 e-150 which way does the arrow point that's on the control valve? There is currently no valve it has a manual shutoff valve installed that someone put on when replacing the old one so I don't know which way the arrow points.
Mar 15, 2026 at 5:16 PM
So the arrow goes in the way the coolant flows, but it should work either way. Ken
Mar 17, 2026 at 9:02 AM
ROBERT GIVENS
  • 5 POSTS
Hi Ken Thank you very much for your help. I have one other question I want to change the rear axle lubricant does it require any additives such as a slip agent to the new lube? It's a 10 bolt rear axle and I believe a 3.55 gear ratio. Its a conversion van with a 5.8 lt engine.
Mar 17, 2026 at 11:00 AM
Yes, wee can help but we only handle one problem per thread, please post your new question here, you must be logged in.
Mar 18, 2026 at 8:16 AM
