Rear lift gate lock not working
2004 GMC ENVOY
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARRY KOPSER
No functions on remotes working as well as the manual interior lock switch will not operate the rear hatch.
Replaced the control module in rear hatch but no change to problem.
Jul 20, 2019 at 5:12 PM
These are controlled by the BCM which sounds like it is out but to be sure lets check the fuses. here is a guide to help and the fuse location with BCM replacement instructions below:
Jul 22, 2019 at 11:46 AM
LARRY KOPSER
Ken:
Thanks for the reply. I didn’t see any blown fuses so I guess it must be in the BCM. That is out of my DIY capability. Looks like I will be crawling in and out of the back if I need to use the lock.
Jul 22, 2019 at 1:10 PM
Good job checking the fuses at least you have an idea of what is wrong :) Use 2CarPros anytime, we are here to help. Please tell a friend.
Jul 23, 2019 at 12:40 PM
