Where can i find a rear strut replacement pre loaded. Googled it only front available.
Feb 11, 2020 at 9:04 PM
STEVE W.
CERTIFIED EXPERT
That isn't uncommon. The companies make the items they can sell and the front units are more of an interchangeable item than the rear units as those don't get replaced near as many times as the fronts. Plus the rear mounts are not as easy to replace as the fronts. For the rear units you normally break them down and replace only the struts.
Feb 11, 2020 at 10:58 PM
CERTIFIED EXPERT
They do not offer fully loaded struts for the rear of this car. you will need to separate this coil from the strut your self. here is how in the diagrams below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Feb 13, 2020 at 10:49 AM
ROGERMM65
MEMBER
Ken on a 1997 Malibu struts , will the front 3 1/4 bottom hub bracket be the same as the rear struts?
Mar 3, 2020 at 6:13 AM
STEVE W.
CERTIFIED EXPERT
The brackets are different front to rear. The early rear strut unit holes are 3.25 apart. The fronts are 3.5 and located in different areas on the bracket as well. The front and rear struts also have different spring seats and damping calibration. Plus the rear struts extend through the mount bracket where the fronts are even with it to provide room for the axle and CV joint.
Mar 3, 2020 at 7:40 AM
ROGERMM65
MEMBER
Thanks , this Chevrolet is proving to be a one off replacement parts kinda confusingly.
Mar 3, 2020 at 10:50 PM
STEVE W.
CERTIFIED EXPERT
GM changed the strut design mid year on the rear. Take a look at rockauto, they had a few options listed for early and late units.
