Removed secondary air pump
2003 VOLKSWAGEN JETTA
116,800 MILES • 1.8L • 4 CYL • TURBO • 2WD • MANUAL
WOLF03
I removed the factory air filter and installed a cold air intake system, I was advised to remove the secondary air pump for a proper balance of the air/ gas ratio. If I remove that pump, what are my chances with that air/ fuel balance
Sep 23, 2019 at 10:46 AM
The air fuel mixture is controlled by the oxygen/map/maf sensor inputs if you remove the secondary pump it should be able to calibrate and be okay. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Sep 24, 2019 at 12:50 PM
