Replacement fuse for 12V power outlet in the center console
2005 MITSUBISHI MAGNA
110,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
WOFTAM
MEMBER
1 POST
FOLLOW
What is the location of the fuse for 12V power outlet in the center console-mail? What is it labelled as?
Oct 23, 2019 at 6:09 AM
CERTIFIED EXPERT
There is a fuse #9 that needs to be checked. but there is also an accessory relay that needs to be checked as well. here is the wiring diagrams so you can see how it works with two guides to help you with the testing:
