Rich fuel/air mixture
1996 TOYOTA COROLLA
250,000 MILES
MARIOC68
  • 120 POSTS
I inspected the spark plugs and noticed that all are with the electrodes of dry black color, only one is black and wet.
What steps should I take to identify the problem?
Feb 11, 2018 at 3:51 AM
The first thing you should do is take a compression test. Here is a guide to help us get started. It sounds like you will have low compression from the cylinder with the wet black plug.
Feb 12, 2018 at 10:51 AM
MARIOC68
  • 120 POSTS
I must perform the compression test by pressing the acceleration pedal thoroughly or not? That does not indicate the reference guide, however I have heard it somewhere.
Feb 12, 2018 at 11:24 AM
No you do not need to open the throttle to take a compression test.
Feb 13, 2018 at 11:53 AM
MARIOC68
  • 120 POSTS
Okay, I will perform the test.
Feb 13, 2018 at 12:05 PM
MARIOC68
  • 120 POSTS
Hi.
These are my results.
In cylinder number three I have the lowest reading so I added a little oil and with this went up.
Feb 13, 2018 at 2:22 PM
Compression is not the problem I am starting to lean toward a bad fuel injector. I would remove them to do a manual test.
Here is a guide
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Feb 14, 2018 at 9:59 AM
MARIOC68
  • 120 POSTS
Check the injectors according to the guide. They seem to be working normally. However, perform a pressure test on the injection system, the results are: Pressure w / vacuum 38 to 40 psi (nominal, according to manual 33 to 38 psi); without vacuum 48 psi (nominal, according to manual, around 42 psi). In addition, after turning off the engine, the pressure gradually falls to zero in less than 1 minute, this should be maintained at least 1.5 kg / cm2 after 5 minutes. I tried to throttle the return hose but it still does not maintain the indicated pressure.
Feb 14, 2018 at 4:19 PM
The fuel pressure is not the problem. I am starting to elan toward a broken oil control piston ring. How does the engine seem to run?
Feb 14, 2018 at 8:18 PM
MARIOC68
  • 120 POSTS
It feels heavy to start in the morning, like it was rich.
Feb 15, 2018 at 3:49 AM
Can you remove the spark plugs and shine a flashlight down into the holes to see the tops of the pistons? This will tell us for sure you might need to rotate the engine a little to see each piston top let me know how each of them looks.
Feb 15, 2018 at 10:48 AM
MARIOC68
  • 120 POSTS
Hi. I checked the operation of the TPS sensor. First I determined the connector terminals with the cables coming from ECU:. One gave voltage 5.0, another zero voltage (ground) and the other voltage 4.1 (signal). Then, connect the voltmeter's pins to the terrestrial and signal terminals (connector inserted to TPS and ignition ON) to see the voltage variations by gradually opening the accelerator. Posion closed, zero voltage, just opened and rose suddenly to 4.1 and remained there until fully open position. I think something is wrong with the TPS, it is assumed that the increase is gradual, however I barely pressed the accelerator and went to 4.1 V.
Feb 16, 2018 at 4:38 AM
MARIOC68
  • 120 POSTS
Also check the oxygen sensor signal (from a single cable), with the engine hot and running. Reads me 0.93 or stable 0.92.
Feb 16, 2018 at 7:48 AM
MARIOC68
  • 120 POSTS
I checked the calibration of the valves.
The manual states: Intake 0.15-0.25mm. (I have a single valve out of range, 0.13mm)
Exhaust 0.31-0.41mm (I have all below the minimum with values from 0.20mm to 0.28mm).
That can explain the excessive consumption of oil and fuel?
Mar 2, 2018 at 5:29 PM
Sorry for the work but I need to see the color of the spark plugs can you remove them and shoot a picture of them keep them in their respective holes. Still leaning toward a broken piston oil control ring. I would replace the TPS the reading look off to me.
Mar 3, 2018 at 1:17 PM
