Roaring sound and vibration when accelerating and rattling underneath?
2005 FORD TAURUS
110,900 MILES • 3.0L • V6 • 2WD • AUTOMATIC
1977WIMMS
  • 28 POSTS
So, when i put the car in drive and take off it is making a growling sound like an airplane taking off as i accelerate and gets quieter as i slow down and at times the gas pedal vibrates when pressed and I'm noticing it feels like it's working harder to get up speed on inclines. When i go over bumps i hear what sounds like chains or something rattling underneath. So, I'm wondering if it's the wheel bearings, an exhaust or vacuum leak, or something else.
Sep 13, 2022 at 7:52 AM
MIKE H R
  • 3,094 POSTS
My first thought is reading your post is that it may be the catalytic converter when they start going bad, they have a tendence to start to clog up and cut down on your exhaust. The rattling you hear may be the converter coming loose and rattling. If you drive a lot at night, try something. After driving and the engine is warm look under the car and see if the converter has a red glow. That would tell your converter is clogging up. When they start to go bad, they will cut down on the exhaust, cutting down on the power. There may be other things but that is where I would start looking.
Sep 13, 2022 at 10:00 AM
It does sound like a bearing hub is going out which is common, does it change pitch when you steering car right to left? If so, this is a clear indication the bearing hubs are bad. Here is how you can change them out in the images below. Also, I found a video for you.
https://youtu.be/x_qTpbkWXQA
Here is the part on Amazon both for $86.00:
https://amzn.to/3Bcn2eO
Sep 13, 2022 at 10:01 AM
1977WIMMS
  • 28 POSTS
my 1st thought was the bearings but then i looked more online it says that it could be an exhaust leak my check engine light is on and Orielly's says it's the 02 sensor, but they don't make noise like this, do they?
Sep 15, 2022 at 7:50 AM
MIKE H R
  • 3,094 POSTS
just to eliminate the converter. When the car is cold use a hammer and gently tap the converter. If it is the converter makes a rattling sound inside the converter. With it rattling going over bumps and now the O2 sensor the exhaust might not be getting clogged up. That would cause the loss of power reaching normal speed and going up a hill. the converter rattles when they go bad from breaking up inside.
Sep 15, 2022 at 9:33 AM
