Rough idle
2003 LINCOLN NAVIGATOR
143,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
TROUBLE1980
  • 49 POSTS
Hi, my SUV has no check engine light on but starts rough, when at a stop it idles so hard it violently shakes back and forth you can see the front of my car lift up and down so bad you would think i have four grown men bouncing up and down on my car. At times when I start the car I have to wait forty five seconds to a minute to put in drive if I do not wait it will just shut off. Car drives fine while driving 25 mph to 70 mph but as soon at I come to a stop I have to throw into park and keep the rpm above 1,000 or it will start to shake and then shut off. Please help
Feb 14, 2019 at 5:52 PM
Many things can cause this type of issue. Often times an engine vacuum leak can be an issue. Most commonly on these vehicles is a vacuum hose which routes from the rear of the throttle body and goes to a 90 degree bend. The bend will dry rot and cause a leak. Additionally, there is a component called an idle air control valve (IAC) which controls idle speed. If that is plugged or not working, it will cause the engine to stall, but if you place it in neutral and it idles fine, that wouldn't be a prime suspect.
Here is a link that discusses engine stall at idle. Take a look through it to see if it is helpful.
https://www.2carpros.com/articles/stall-at-idle
Here are links that discuss the IAC and how to check for a vacuum leak:
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Next, if there is a problem with the fuel pressure regulator which is allowing pressure to be too high, it can cause this type of problem. To check this component, you would need to perform a fuel pressure test along with checking the regulator. Here is a link that shows how that is done:
Before you go through the fuel pressure test, locate the fuel pressure regulator which is located on the fuel rail. There is a vacuum hose attached to it. Remove the vacuum hose and confirm there is no raw fuel in it.
Here are the directions for removal and replacement of the regulator. The attached pictures correlate with these directions. I attached these directions in case you determine the regulator is the problem.
FUEL PRESSURE REGULATOR
REMOVAL
WARNING:
- Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel-related components. Highly flammable mixtures are always present and may be ignited. Failure to follow these instructions may result in personal injury.
- Fuel in the fuel system remains under high pressure even when the engine is not running. Before working on or disconnecting any of the fuel lines or fuel system components, the fuel system pressure must be relieved. Failure to follow these instructions may result in personal injury.
1. Relieve the fuel pressure.
2. Remove the upper intake manifold.
Picture 1
3. Remove the fuel pressure regulator.
1 Disconnect the fuel pressure regulator vacuum hose.
2 Remove the snap ring.
3 Remove the fuel pressure regulator.
Picture 2
4. Remove and discard the fuel pressure regulator O-ring seals.
INSTALLATION
1. CAUTION: Use O-ring seals that are made of special fuel resistant material. Use of ordinary O-ring seals can cause the fuel system to leak. Do not reuse O-ring seals.
NOTE: Lubricate the new O-ring seals with clean engine oil to aid installation.
To install, reverse the removal procedure.
___________________________________
I realize this is a lot of information. However, since there are no diagnostic trouble codes, it requires a lot more diagnosis. There are other things that will need checked if these things don't prove to be an issue. From experience, your description sounds like either a vacuum leak, IAC is plugged, or fuel pressure it too high.
Feel free to ask me questions if you have them. Also, let me know what you find.
Feb 14, 2019 at 7:04 PM
TROUBLE1980
  • 49 POSTS
Joe thank you for your expert opinion I appreciate it. I had no clue where to start looking for the problem and didn't want to just throw money away chasing the problem with no end in sight. Thank you. I will keep you posted and keep you in mind if I have anymore questions. Hope you have a good day.
Daniel Wilson
Feb 15, 2019 at 9:18 AM
Happy to help. Let me know if you have other questions. Also, after I replied yesterday, another thought came to mind. There is a coolant temperature sensor the computer uses to determine the air fuel mixture injected into the engine. If the sensor is sending an incorrect temperature reading, the mixture will be off. For example, if the computer is told it is -40 degrees outside but in reality it is 75 degrees, the fuel mixture will be much too rich.
Pay attention to when it is happening if the exhaust is putting out black smoke. That would indicate too much fuel is getting into the engine. Also, if you have access to a live data scanner, you can actually check what temperature the sensor is telling the computer and make a determination if it is accurate.
Let me know what you find or if you need help.
Feb 15, 2019 at 2:17 PM
TROUBLE1980
  • 49 POSTS
Joe thank you! i am probably going to give the list you gave me to my mechanic. I have basic knowledge when it comes mechanic work but I think figuring this out by my self might be too much for me to handle lol. I will check the basic stuff you said to check first though, I will definitely keep you posted. I have used 2CarPros before and have helped and saved me a lot of money with All of your knowledge this is an amazing way to get help when your just stuck and have no clue. thank you
Feb 15, 2019 at 2:24 PM
No problem. If you find that you do have questions or need anything, let me know.
Take care and if you have the chance, I would love to know what the cause was.
Feb 15, 2019 at 2:29 PM
TROUBLE1980
  • 49 POSTS
Hello Joe,
Sent truck to my mechanic he checked everything on the list and couldn't figure out or find the problem. He suggested I take it to a Ford dealership and have them run a diagnostic check since my truck isn't throwing a code. So on my way home from picking it up it finally has a check engine light the code is 2195, do you have any suggestions where I should look first to fix the problem?
Thank you,
Daniel
Mar 8, 2019 at 4:15 PM
I think I know what is wrong. You have a major vacuum leak. I need you to check a few specific hoses. First, you will see where two hoses attach to a component above and to the left of the brake booster. Closely check both hoses for damage, dry rot, or anything that could cause a vacuum leak. Next, along the rear of the engine are other larger vacuum hoses which commonly dry rot, melt... and create a vacuum leak. Check all hoses back there. Also, check the large vacuum hose that runs from the rear of the intake to the valve cover on the passenger side (PCV). Some of the hoses are somewhat hidden under the cowl, so take your time. If you look at pictures 1 and 2, it shows the purge solenoid which is the part I referred to which is to the left of the brake booster. You can see the two hoses that attach. Follow them all the way back to the intake. In picture 2, the black arrows are pointing to the hoses. Picture 1 is the same part from a different view. I added it because it shows a portion of the brake booster to help you locate it.
Now, here is a link that shows how to check for a vacuum link using starting fluid. If you choose to use this procedure, make sure to follow the directions. The bottom line is carburetor cleaner is flammable. Make sure to avoid spraying it onto anything that is extremely how such as an exhaust manifold.
Also, if you open the hood and start the engine, you may be able to actually hear the leak. If you do hear it, gently move around the vacuum hoses I mentioned to see if there is a change in the sound.
Let me know what you find and I feel confident this is the problem.
Mar 8, 2019 at 6:55 PM
TROUBLE1980
  • 49 POSTS
Joe,
My mechanic completed the third smoke test today and is saying there is absolutely no smoke coming out of anywhere, he did the fuel pressure test also before but is going to do one closer to the fuel pump, and he has sprayed ether and my o2 sensors are working. It is running lean on bank 2 or something of that nature. he was telling me and the only thing left after the fuel pressure test he is going to run tomorrow is the fuel injectors and fuel rail. He said usually the code on Fords are a easy issue to find and fix but he can not figure this scenario out yet. In your opinion would the injectors be your next move?
Mar 14, 2019 at 1:45 PM
Welcome back:
Were the specific hoses I mentioned checked?
Mar 14, 2019 at 5:55 PM
TROUBLE1980
  • 49 POSTS
Hi Joe I'm not sure, I will show him your previous reply and let you know, I was assuming that a smoke test would be sufficient on all vacuum hoses that would have wear, I am not a Expert, as you are. So I will definitely have him check them if he has not and let you know. From what he Has told me he has checked every other option you have brought up and they where all fine so I'm hoping I can have this matter resolved soon! I am a Union Carpenter and I travel quiet a ways away for work and its been hard the past few weeks ,so i have my fingers crossed we can figure it out within days! I appreciate all your help!
Thank you,
Daniel Wilson
Mar 14, 2019 at 8:17 PM
Not a problem, Daniel. My father was a union mason and taught me a lot about stone work. I remember well him driving a lot for work. I know construction isn't easy!!!
Let me know. I have to be honest, I feel he is missing something.
Mar 14, 2019 at 9:12 PM
TROUBLE1980
  • 49 POSTS
Joe,
I also was a Stone Mason owned my own Stone Mason Business for almost 3 years Good Stone masons are hard to find , Thats why I had to let the business go couldn't find qualified workers up here in Ohio. & Yes I agree I also feel there's something he has to be missing as well! He has been my mechanic for over 8 yrs and is not changing me a dime to find the problem, the only problem is he isn't continuously working on just my car just periodically through out the day trying to troubleshoot the code. He said he does know it is bank 2 & its extremely rich. So he has till tomorrow before I have to find somewhere else to rake it with "new eyes"
Mar 14, 2019 at 9:28 PM
Okay, that doesn't sound right. The code is for a lean mixture. Did he tell you it's extremely rich? That's the opposite of what should be happening. And, it is related to bank 1. Also, is this a natural gas vehicle? Take a look at picture 1. The code is related to a lean mixture.
Mar 14, 2019 at 9:40 PM
TROUBLE1980
  • 49 POSTS
Yes, sorry lean.
Mar 15, 2019 at 6:58 AM
TROUBLE1980
  • 49 POSTS
Okay, so we decided where sending it to another shop my mechanic checked the hoses you told me to check ,no problem there, He feels it needs new eyes also lol. so Tuesday we will see if we can figure it out. I'll keep ya updated, thanks for all your help!
Mar 15, 2019 at 1:03 PM
Happy to help. Let me know what the other person says. I am really interested in knowing.
Take care and have a nice weekend.
Mar 15, 2019 at 7:49 PM
TROUBLE1980
  • 49 POSTS
Joe thank you and I hope you enjoy your weekend as well.
Mar 15, 2019 at 10:33 PM
TROUBLE1980
  • 49 POSTS
So bad news, still no answer. the other place ran every test you said to have ran and still they have no clue what the problem is. they even had another mechanic with fifty years experience look, He also has no clue. He suggested to run a fuel injector test to see if that could be the problem, after that test if it is not conclusive they don't know what I should do! Please what are your Thoughts, I'm at my wits end and have exhausted all my options my mechanic and the other three said after this test they do not and will not spend any more time or resources trying to find the problem with out charging me shop time to [try] to find out how to fix the problem. I have not paid a dime.
Mar 20, 2019 at 3:47 PM
Wow.. I still feel it is a vacuum leak issue. However, I may be wrong. Anytime there is a lean mixture, it is either fuel pressure is low, the injectors are plugged, or there is a vacuum leak. If I recall, pressure was tested. As far as injectors, the chances of all eight being partially plugged is slim. That leads to a leak. Did they check for a leak using carburetor cleaner?
Take a look through this link:
Let me know. It may have to go to a Lincoln dealership.
Mar 20, 2019 at 6:28 PM
TROUBLE1980
  • 49 POSTS
Joe I'm not sure if they used carburetor cleaner, I do know they smoke tested it. The mechanic I use has been working on cars and owns his own shop and has for the past twenty years he should know. He can do that I hope lol, and his old boss is who I sent it to. he also ran all the tests and I hope would know to do that also but who knows. I will have to ask tomorrow they also had another mechanic take a look who used to work for a Ford dealer and he is basically saying what you are but from what they are telling me he us stumped too.
Mar 20, 2019 at 7:08 PM
TROUBLE1980
  • 49 POSTS
Joe, I went back and listened to my conversation with him I had today and he was saying the code is only for one bank not both but the fuel trim is reading both sides at +40 and should only read -5 to +5. basically it is starving for fuel. Not sure if that helps with anything but they do know that but not why the fuel trim readings are +40.
Mar 20, 2019 at 7:41 PM
Welcome back:
This is a tough one. If I had the vehicle, here is what I would do and in this order.
1) Confirm there are no other codes in addition to the 2195.
2) I would check freeze frame data to see if there is anything I can use to pinpoint any specific issue.
3) If nothing is found with freeze frame data, I would then carefully inspect the wiring to the O2 sensor for fraying, damage, connection, corrosion and so on.
4) If the wiring was good, check for vacuum related issues and repair as needed.
5) If that checks good, confirm there are no exhaust manifold leaks on that bank. The 5.4 is known for leaks.
6) If nothing was found, I would replace the O2 sensor.
The +40 on the scanner indicates the computer is trying to compensate for a lean mixture by making the fuel mixture richer. I would expect it to be like that.
Now, earlier you mentioned that the O2 sensors were checked. I'm starting to question if the sensor itself is bad.
Mar 20, 2019 at 9:21 PM
TROUBLE1980
  • 49 POSTS
Joe, my mechanics old boss the second guy I took it to actually put in a new O2 sensor just to make sure and the number's stayed the same and there are no new codes still just the one. that is why they are stumped as well. I will keep you updated as to what they say about the fuel injectors today. Thanks Joe I appreciate it.
Thank you,
Daniel
Mar 21, 2019 at 3:27 AM
Daniel:
This is a tough one. I wish I could be of more help, but everything which makes sense doesn't check out. Are there any exhaust leaks?
Let me know what you find. I would love to be there and see what is causing it.
Mar 21, 2019 at 6:29 PM
TROUBLE1980
  • 49 POSTS
Joe, yea I wish you where here also. Because I have no clue what is going on all I know is I'm relaying your opinions and I'm being told they have checked everything I'm telling them to check. And yes I think I have a a exhaust leak because there is a strong exhaust smell that comes from the front of the car.
Mar 21, 2019 at 6:56 PM
TROUBLE1980
  • 49 POSTS
& also they where supposed to run some type of fuel injector cleaning method today and I never heard from them,So I dont know if they did it or it didn't help or show what is wrong
Mar 21, 2019 at 6:59 PM
They are aware that an exhaust manifold leak can cause a lean mixture, correct? The 5.4L is known for the exhaust manifolds to leak. It's just a thought because I have seen that happen in the past.
Mar 21, 2019 at 7:05 PM
TROUBLE1980
  • 49 POSTS
I would hope so! It hasn't been brought up, and honestly didn't even think to say something about the smell, and honestly didn't know that would cause a lean mixture, Do you think that could be the problem?
Mar 21, 2019 at 7:08 PM
Take a look at part 4 of this link:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
The codes are indicated are not for all vehicles.
Mar 21, 2019 at 8:33 PM
TROUBLE1980
  • 49 POSTS
Wow, I would have never thought that could cause a o2 sensor to do that. I will definitely tell my mechanic to check it out asap. Thank you Joe. I will let you know what the findings are as soon as I hear something.
Mar 21, 2019 at 9:45 PM
TROUBLE1980
  • 49 POSTS
Joe, I don't think where going to figure this one out, They believe it has something to do with the timing because they can hear a ticking sound when the car first starts up and I'm not willing to pay to find out if it is or pay the cost to have that fixed. So to the scrap yard is where it will probably end up. I have a 1985 Camaro that needs a little work done and as for right now with the weather starting to break in Ohio it will be a cheaper route to get me back driving. Thank you for all your help and time I appreciate you, and wished we could have figured it out.
Mar 22, 2019 at 1:19 PM
The ticking noise they hear, does it go away when the engine warms up? I'm near Pittsburgh, so I know once the engine starts to warm up, a cracked or leaking manifold can expand and the noise go away.
By the way, you are very welcome. I wish we could have gotten it fixed.
Let me know about the ticking. Also, let me know if they checked for that.
Mar 22, 2019 at 8:58 PM
TROUBLE1980
  • 49 POSTS
Joe they said the ticking does stop after a few minutes & they said there is a small leak in the manifold but there is no way to find out if the manifold is causing the problem with out fixing it and seeing if that works, & they believe its the timing causing the problem priced around $1,200/$1,800 to fix I'm just not prepared to let it become a money pit and keep THROWING $$$ at it to find the problem & its been over 3 weeks & over 5 Certified Mechanics who own reputable business with atleast 30+ years experience each and they can't guarantee what they think it is they want me to pay to "maybe " fix I'm very disappointed because other than this the Navigator is in great shape! As a Husband and father of 4 my priorities are to save $ there I can and just give up on it for now the Camaro only needs gas lines ran & shocks so I will probably just park the Lincoln till I have the cash to really invest into it. If they figure something out before I pick it up Monday ill let ya know but its not Looking like we will figure it out. Thanx again Joe I hope you enjoy your weekend.
Mar 22, 2019 at 9:24 PM
You are welcome and you too have a nice weekend.
Mar 22, 2019 at 9:36 PM
TROUBLE1980
  • 49 POSTS
Thank you!
Mar 22, 2019 at 9:37 PM
JACOBANDNICKOLAS is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 25, 2019 at 11:30 AM
TROUBLE1980
  • 49 POSTS
Joe, I have a new problem but with my 1985 Chevrolet Camaro, are you able to help me with this car?
Mar 31, 2019 at 5:59 PM
TROUBLE1980
  • 49 POSTS
I just put a new 140 volt alternator in because I thought my old 80v or 100v was not enough power, While in drive and driving it read's +13/14 but while stopped at a light it dips down to red within twenty seconds that's with nothing on no lights or radio. With lights and at a light same problem. While in park with lights on stays around 13. So when driving at all stop light I have to put it in park and take my foot off the brake. Please any help would be appreciated i am down to only this car since we never figured out the Lincoln situation.
Mar 31, 2019 at 6:10 PM
Welcome back:
You aren't having much luck. Yes, I would be happy to help. However, I need you to start a new thread. We are trying to keep different problems separated. While you are reposting the issue, make sure the belt is tight and the idle RPM's are within spec. Let me know in your new post what you find.
I hope you understand. I will watch for your post.
Mar 31, 2019 at 7:01 PM
TROUBLE1980
  • 49 POSTS
Joe good to hear from ya again, I am not sure how but I will try to figure out how to start a new post now.
Mar 31, 2019 at 8:22 PM
