Runs and then shuts off
1996 FORD THUNDERBIRD
121,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ROSCOE6355
Runs really well for twenty to thirty minutes, and then stalls and is hard to start. Replaced almost every sensor in it. This all started from a radiator hose that blew and shorted out stuff. I am at my wits end . What can it be?
Oct 31, 2017 at 12:22 PM
To me it sounds like you have a main power (constant control) relay that is worn and fails when hot or the ECM is going bad doing the same thing. Here are some guides and diagrams so we can see whats going on when the engine stops running.
Does the engine lose spark or fuel?
and
Here is a guide to check the main engine computer relay
Here is its location (below) if everything checks out I would get a used ECM engine control computer and plug it in.
Nov 2, 2017 at 11:04 AM
ROSCOE6355
Very informational, but replaced Cam Shaft Position Sensor, runs like a champ again, really replaced most of the sensors, check all radiator hoses and changed out two more. Hot water and sensors don't mix
Nov 4, 2017 at 9:07 PM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Nov 5, 2017 at 1:33 PM
