2002 Saturn SC2 Miss firing
2002 SATURN SC2
110,000 MILES • 4 CYL • FWD • MANUAL
WISKO17
At first i had some problems with the car not running on all cylinders. then i tried to replace the plugs and wires. but when i did the car started miss firing more than it have before. I checked the firing order and it seemed to be right. So would my next step would be to change the Ignition coil?
Dec 27, 2008 at 3:42 AM
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Dec 27, 2008 at 3:46 AM
