Security wiring diagram
2005 INFINITI FX45
250,456 MILES • 3.5L • V6 • 4WD • AUTOMATIC
PETEROS
My problem is , I have dtc P1610 and two keys are good. I can make diagnostic in both ECU, ( BCM and ECU ) my problem is that code avoid my car to start. I need wiring diagram to control wise maybe some wire not connected. Because turn signal not working and central lock. Thank you for help.
Jun 13, 2018 at 5:11 PM
Here is a guide to help you test the wiring and power with grounds and the wiring diagrams for the security and forced entry systems:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jun 19, 2018 at 11:42 AM
PETER MBONIGABA
Thank you very much Mr Ken, your diagram helped me. I found a problem was in inside BCM. Water was entering in BCM through sun roof, wiring was good. Thank you for your help, I appreciate it.
Jun 20, 2018 at 12:21 PM
Good to hear, please use 2CarPros anytime we are here to help.
Jun 21, 2018 at 11:44 AM
