Shifting problem
1995 PONTIAC GRAND PRIX
181,231 MILES • 3.1L • 6 CYL • AUTOMATIC
DOUG MCCLUSKEY
  • 10 POSTS
When i drive my car it will not shift into overdrive. But after a few miles i can stop and shut it off, then restart and drive again and it will shift properly.
Nov 18, 2017 at 7:03 PM
1995 was the first year for the OBD 2 diagnostic system. With that in mind, has the check engine light ever come when this happens?
Nov 18, 2017 at 9:12 PM
DOUG MCCLUSKEY
  • 10 POSTS
Sometimes it will. And sometimes not. I have had it plugged in but it has shown nothing.
Nov 19, 2017 at 2:47 PM
Do you have a scanner that will read transmission codes? Most inexpensive ones won't.
Nov 19, 2017 at 4:49 PM
DOUG MCCLUSKEY
  • 10 POSTS
O'Reilly has tried but nothing.
Nov 19, 2017 at 5:01 PM
Usually, the parts stores only have scanners that will read engine codes. With that in mind, confirm with them that they had one that will.
Nov 19, 2017 at 6:07 PM
DOUG MCCLUSKEY
  • 10 POSTS
Ok i will ask them. But in your opinion is this a possible chance of jyst a short somewere
Nov 19, 2017 at 6:10 PM
To me it sounds like you have ECM that is going out becasue when you reset the system it starts working again. Have you serviced the transmission lately?
Here is a guide to give you an idea of what you are in for when doing the job.
Also here is the location of the ECM I would try to get a used one and plug it in to see if this is the problem.
Nov 22, 2017 at 11:22 AM
