spark plug wire order
2006 DODGE CARAVAN
212,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
TISHA GREENHAW DARROW
I see on this website under questions you have answered, a chart for a 2005 Dodge Caravan for the spark plug wires. I have the van listed above it is a MFI OHV. Would I use the same chart for changing the wires? I already took off the old wires, but did not know that I should have done them one at a time, or that the order mattered. So I am looking for the right order.
Nov 15, 2017 at 2:03 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Here is that firing order:
Nov 15, 2017 at 4:10 PM
T3ACH3R
Engine Performance problem 6 cyl Two Wheel Drive Automatic 50000 miles
the 2 plug and wire is bad i need to know where it is on the block. I love this site
Jun 19, 2020 at 1:08 PM (Merged)
The engine ignition firing order is
Firing Order 1-2-3-4-5-6
The cylinders are numbered from the front of the engine to the rear. The front cylinder bank is numbered 2, 4, 6. The rear cylinder bank is numbered 1, 3, 5.
BRENDA,
i would like to know what the firing order is for this vehicle
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_2_57.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_113.jpg
WULVE50
I need to know the firing order so I can re-attach the spark plug wires in the right order. It is a 3.3 liter six cylinder.
Jun 19, 2020 at 1:09 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Here is the engine ignition firing order to help you get back on the road the four cylinder diagram is below
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_488.jpg
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
IZHART
my van was driving roough so I changed spark plugs and wires it starts great but does not drive over 25 with out problemswhat is the firing order for the plugs
SERVICE WRITER
  • 9,123 POSTS
There should be codes I would expect in the pcm to give some insight to this. It may be transmission related, restriction in the converter are the two first things that I think of.
DIRTYSOUTH6PAK85
yes i would like to know the fireing order for a dodge caravan 2000 3.0
SERVICE WRITER
  • 9,123 POSTS
you can 100% sure on the compliancy, there is probably a cummunication error, start with the simple thing and check the fuse for the data link connector.
https://www.2carpros.com/forum/automotive_pictures/73973_30CaravanDist_1.gif
DDCYR40
  • 41 POSTS
where would I find that, and how would I access it? thanks
SERVICE WRITER
  • 9,123 POSTS
Doug, I was mistaken, according to the diagram it goes right into the ecm. There is a communication problem by the description, is the connector good?
I was off base on that one.
DDCYR40
  • 41 POSTS
i wouldn't know how to check, i know i unplugged it and plugged i back in and wiggled it around. could it be the scanner or just having a fit? you would think it would work, especially since there is a MIL on???
SERVICE WRITER
  • 9,123 POSTS
Best I can say it try the scanner on another car, if it works, then contact the scanner manufacturer for insight.
2CP-ARCHIVES
  • 4,540 POSTS
what is the firing order for a 3.3 litre V6?
Jun 20, 2020 at 10:49 AM (Merged)
Here is the engine ignition system firing order in the diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
