Sputtering, I have replaced the IAC, TPS all six plugs and coils?
2005 JEEP LIBERTY
223,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
JOSHUAMO2
I have replaced the IAC, TPS all six plugs and coils, PCV valve o2 sensor and I am still having intermittent start issues and bogging out low power low fuel mileage no vacuum leaks I can’t seem to find the issue all plugs are gapped at vehicles specifications.
Sep 26, 2022 at 2:08 PM
It sounds like the engine is misfiring, but I can tell for sure if you upload a short video of the engine cranking, and then running. In the meantime, please run the codes.
Also, with this many miles we should do a compression test which you can rent the gauge from the auto parts store for cheap.
Take note of what the spark plugs look like compared to each other. This can be a clue to the problem cylinder.
Please go over these guides and report back.
Sep 26, 2022 at 5:01 PM
JOSHUAMO2
I ended up finding out #5 was misfiring without a code thrown until I turned on the A/C one of my new coil packs was intermittently failing.
Sep 26, 2022 at 5:58 PM
It happens, thanks for getting back to us. Use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 27, 2022 at 12:31 PM
