Stabil Trak and Traction Control?
2008 BUICK ENCLAVE
130,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
MICKEY2EYES
  • 7 POSTS
Hello Pros, I’m getting the Service Stabil Trak warning just before “Reduced Engine Power” then have to pull over- kill the engine- remove keys- open and close driver door- and while waiting 10 seconds before a restart and continue on my way, I glance at my reflection in the rear view to judge the depth of my frustration.
It seems to drive further if I turn off Traction Control 1st thing when I start the car and the issues come when I begin to slow down for traffic, red lights, stops, etc.
For a little insight, we got the car in 2020 as a gift with 113k miles and no known issues. Shortly afterwards the water pump in/out hoses disintegrated and replaced then the water pump. In ‘21 the car wouldn’t shift into 2nd and 3rd occasionally and was told that it could be Wave Plate disintegration particles?
Also, in May of this year she began overheating with no visible leaks, so I added some FiberLock HG and Block Repair which did the trick. Great stuff btw.
I’m trying to locate my scanner and once found I’ll drop the codes here. Until then, any help will be greatly appreciated.
Here are the codes:
P0011- A Camshaft Position Timing Over- Advanced or System Performance Bank 1
P0014- B . . , Etc.
P0121- Throttle/Pedal Position Sensor/Switch A Circuit Range/Perf.
P0330- Knock Sensor 2-Circuit Bank 2
P0700- Trans. Ctrl. Sys. (MIL Request)
P1400- Manufacturer Ctrl.
P1516-
P2135- Thrott/Pedal Pos. Sensor/Switch A/B Voltage Correlation
P0121- / / Switch A Circuit Rng/Perf
Hope this helps.
Thanks for reading my rambling.
Nov 19, 2022 at 10:24 AM
So, the car is going into limp mode, these codes:
and
P2135- Throttle/Pedal Pos. Sensor/Switch A/B Voltage Correlation
Are the ones I think ae causing the problems, I would service the throttle body first and then clear all codes here is a guide to help walk you through the steps and instructions for your car in the images below.
If you leave the wiring connected you should not need to relearn the throttle actuator. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Nov 20, 2022 at 11:05 AM
MICKEY2EYES
  • 7 POSTS
Thank you, Ken, and thanks to daylight saving time I’ll have to try this tomorrow with more daylight, saving time and money. I’ll definitely upload pics or a video to share.
Nov 21, 2022 at 3:14 PM
Sounds good!
Nov 22, 2022 at 10:08 AM
MICKEY2EYES
  • 7 POSTS
That did the trick. I tried to upload some pics and a video but it all disappears when I click reply. Tried 3 times to no avail.
Make that 6 times.
Nov 23, 2022 at 10:16 AM
MICKEY2EYES
  • 7 POSTS
I thank y’all so much. Saved me a bundle and the stress just melted away. Y’all rock like The Clash.
Nov 23, 2022 at 10:25 AM
Good to hear, please use 2CarPros anytime we are here to help.
Nov 25, 2022 at 9:11 AM
