Stalls after it warms up
1987 NISSAN STANZA
108,000 MILES • 1.9L • 4 CYL • MANUAL
RVS
Changed the plugs, the ignition module on the intake side now it is worse and the tachometer quit working.
May 26, 2018 at 4:21 PM
It sounds like the tachometer has stopped working because the ignition module might be the wrong one. The engine runs perfect when cold and then stalls when warmed up means one of the things a vacuum leak or you have a coolant temperature sensor that is messing up.
Here are guides you can go over to see if you can find the problem:
https://www.2carpros.com/articles/stall-at-idle
and
May 28, 2018 at 10:43 AM
RVS
Checked for vacuum, did the squeeze test and sprayed carburetor cleaner on all vacuum connections. aAll checked out good. Where is the coolant temperature sensor ?
Jun 10, 2018 at 9:47 AM
Here is the engine coolant temperature sensor location (below):
Jun 10, 2018 at 11:07 AM
RVS
We figured out the problem. There is oil in the distributor. It is a cam angle sensor type . Is there a seal at the base on the distributor shaft? What is the procedure to repair or replace it?
Jun 23, 2018 at 9:51 AM
There is no seal but the distributor can become worn allow clearance between the shaft and the housing. I would get a rebuilt unit and install it.
Jun 23, 2018 at 12:04 PM
