When applying the brakes the steering wheel shakes violently?
2014 KIA OPTIMA
178,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
STORM SPICER
When applying brakes the steering wheel shakes very aggressively no matter the speed. The sound it makes is coming by the telescoping lever underneath the steering wheel above the brake pedal. I turned the steering wheel back and forth without the ignition on and it made a metal-on-metal noise.
Dec 21, 2024 at 12:42 PM
STORM SPICER
Video clip.
Dec 21, 2024 at 12:44 PM
Thanks for the video, it helps. To me I would look at the front rotors which if they are warped it will make this sound/action. If they are okay, it sounds like the power steering motor is going out, which is common. Here is the location of the motor and a guide to help as well so you can check it out.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
You might be able to do a CAN scan which if the system has a code, it will help confirm the issue. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Dec 23, 2024 at 11:41 AM
