Sorry for the delay. I understand the problem. Hadn't considered the rounded head. If that's the stud on the lower ball joint you're fighting with, banging on the knuckle usually shocks the stud loose. You can also try a "pickle fork". That has a pair of teeth on the end of a shaft that you can pound in to wedge the parts apart. The problem with those is they usually damage the rubber boot on the ball joint.
Another thing to consider is welding a nut to the bolt head. You have it apart enough for that. There's a few tricks, though, to make that work. First, you need a way to hold the nut in place. If you have a helper, he can hold the nut in place with a pointed-tip locking pliers. The next secret is you have to heat the bolt head first with an acetylene torch. Propane torch will not get anywhere near hot enough. Once the bolt head is hot, hold the nut on top of it, then go through its hole and hit the welding wire on the bolt head. Try to avoid welding to the nut at first. Once the weld has penetrated into the bolt head, allow it to build up until it runs into the nut. If the welding wire hits the nut too soon, you won't get a good bond to the bolt.
Fill in the hole. The nut will get red-hot right away and melt away if the bolt head isn't heated first. By preheating the bolt head, the weld will penetrate it before the nut starts to melt away. The next secret is to stop welding before the outer hex of the nut melts away.
Once the nut is welded to the bolt, I like to sprinkle a little water on it to shock it and shrink it. A few taps with a hammer can also help to free the bolt. Now try to remove the bolt, but if it still feels really tight, let it cool for a few minutes, then try again.
Don't panic if the nut twists off the bolt. Grab another one and try again. I've had to do this with as many as six nuts before the bolt came out. By preheating the bolt head to red-hot, it helps it to melt into the weld before you completely fill the hole in the nut. Use a wrench or hand ratchet to work the bolt loose. Air-powered impact tools have a good chance of twisting the nut off the bolt.
On some applications, thread-locker is used on those bolts. Heating the bolt softens that material.
Another trick, if you can get in there, is to use an air-powered cutoff tool to grind two new flats onto the bolt head. Keep the head as wide as possible so you can use a larger open-end wrench. Smaller wrenches will have a tendency to slip off.
My last suggestion is to grind the head completely off. That will allow you to remove the bearing with the bolt still in it. If you're replacing the bearing, just find a new bolt in a salvage yard. If you're putting this bearing back in later, there will be about 3/4" of bolt exposed that you can grab with a small pipe wrench, a vise-grip pliers, or even a vise. You can also weld on a piece of metal to use as a wrench.
Let me know if any of those ideas work.
May 8, 2025 at 2:32 PM
