Code p0483, cooling fans will not turn on?
2006 SUBARU LEGACY
140,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
GRAHAM78
  • 10 POSTS
The engine fans won't kick on, even with the A/C on, even if the green connector is plugged in. The car doesn't overheat, per the dash, but just pulled the p0483 code yesterday. has a new radiator and coolant, thermostat, checked out good then, no other known issues except for the A/C clutch not kicking on either. The A/C was working this summer.
Nov 15, 2023 at 5:10 PM
AKASHBARMAN
  • 0 POST
You wrote an informative post, which I found very interesting. In addition to providing a lot of useful information, the article was very enjoyable to read. In your post, you provided a wealth of information, and I look forward to reading more and using the resources you recommended.
Tractor Plough Price Range in India
Nov 15, 2023 at 9:20 PM
The diagnostic trouble code (DTC) P0483 in a 2006 Subaru Legacy relates to the cooling fan. This code indicates "Fan Rationality Check Malfunction,"
If neither fans are working it sounds like the main fan relay 1 is not working but we should check the fuses (3, under the hood and #26 and #22 inside fuse panel) as well, here is a guide to help you check the fuses and if they are okay, I would swap out the relay.
and
Nov 16, 2023 at 10:47 AM
GRAHAM78
  • 10 POSTS
Sorry for the late response, finally got the relay swapped out with no change. Now it's 20' out, so, it is getting harder to diagnose. Still no fan with the A/C on though..
Nov 24, 2023 at 2:35 PM
How are the fuses? do they have power?
Nov 25, 2023 at 9:27 AM
GRAHAM78
  • 10 POSTS
Yes, I'll need to double check though at this point. Now with the weather change, the temperature isn't coming up over 1/4 to 1/3. He used to consistently run at half.
Nov 25, 2023 at 1:52 PM
Also, I would try swapping out the main fan relay one if the fuses are okay.
Nov 26, 2023 at 11:24 AM
GRAHAM78
  • 10 POSTS
That relay has been changed now. I had to wait for a new one before I even messed with it. Subaru has it shrouded right in the fuse box they like to fall apart when removed.
Nov 26, 2023 at 3:23 PM
So, does the fan come on when the A/C is on? If not, I would test the yel/grn wire to the fan motor for power with the A/C on. Here is a guide to help:
Nov 27, 2023 at 9:02 AM
