1998 Subaru Outback cleaned TB now check engine light is on
1998 SUBARU OUTBACK
204,000 MILES • 4 CYL • AWD • AUTOMATIC
BOGUSDILL
  • 4 POSTS
i recently cleaned my throttle body and was carefull not to spray to much STP TB cleaner in the throttle body an it started and ran better than it had for a long time. the next day i was driving it and the check engine light came on. there were 2 codes that popped up, i cleaned the EGR valve to and it works properly. can you tell me what else might cause the check engine light to come on?
Aug 27, 2008 at 3:14 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to check the codes and see what they stand for, and when the problems fixed you will have to get the codes cleared from the ECU.
Mark (mhpautos)
Aug 27, 2008 at 5:42 AM
BOGUSDILL
  • 4 POSTS
the code is P0400 and it means EGR flow malfunction. what could i have done to cause this malfunction? thank you for your help.
Aug 27, 2008 at 7:30 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
There may be that there is a small amount of carbon stuck under the vale causing it to leak when closed.
Mark (mhpautos)
Aug 27, 2008 at 7:47 PM
BOGUSDILL
  • 4 POSTS
thank you i think that mite have been the problem because when i removed it i noticed quite a bit of gunk so i cleaned it out and reset the check engine light and it hasnt come back on yet but im keeping my fingers crossed! if it comes back on are there any other things i should try to do?
Aug 27, 2008 at 11:24 PM
MHPAUTOS
  • 31,937 POSTS
If the code is for the EGR valve don't do anything else, i feel that if you get all the muck out you should be ok.
Mark (mhpautos)
Aug 28, 2008 at 1:01 AM
BOGUSDILL
  • 4 POSTS
well the light came back on after i cleaned the EGR what else could the problem be? do you have any ideas cause im totally lost
Sep 9, 2008 at 2:23 AM
