Suspect of oil and coolant mixture
2001 VOLKSWAGEN GOLF
300,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
GEORGEAS
My car used to overheat I would put in water but water would disappear. So I could not find a leak. So this other day when I tried to start it would not start. Something said to me I should check the oil dip stick and I could see the traces of water in the dip stick. I want to make sure is it really that. What is the best way to fix it my engine? It is dismantled already.
Can I just get a new cylinder head gasket or what else can I check for before mount it back?
Thanks in advance,
George
Dec 5, 2018 at 7:33 AM
When you took it apart did you see any head gasket failure? If not I would have the cylinder head pressure tested to make sure it is not cracked. Can you upload pictures of the suspected bad parts?
Dec 6, 2018 at 10:15 AM
GEORGEAS
Thanks, when I took it apart It was not obvious that the head gasket failed but I will take the advise and send it out for pressure testing. Also when I do a naked eye inspection I do not see any cylinder head cracks. Is it possible to do a visual inspection and would it be obvious to see the failure?
Dec 6, 2018 at 10:00 PM
It is difficult to see cracks with the naked eye. I would also check the cylinder bores as well.
Dec 7, 2018 at 9:08 AM
