Tachometer rpm do not match engine/Secondary cooling fans on all the time
1990 CHEVROLET CORVETTE
115,000 MILES • V8 • 2WD • AUTOMATIC
C4TONEZONE
This past Thanksgiving day driving on the freeway and hit a pot hole pretty hard. I glanced at the tachometer and the needle was in the red line area. As i pulled off the freeway coming to a dead stop, the tach meter was at 5-6000 mark. The next morning, I got the repair manual out and ran diagnostic test and the error code came back as code 42. Turning the key to the on position - engine had not been started, I noticed the secondary cooling fans came on . As per the manual, I erased the error code, and started the car - no fans. Idling for 1 minute, the shut down. Retest the diagnostics - key on-engine off - fans are back on.
The tachometer - with the key in the off position - needle is in rest position. The key in the on position- engine off showed a little movement - but still below zero. Key in the on position - engine on - rpm jump to over 5000k,
Acceleration causes the needle past 6000k into the red line area. key in the on position engine on - AC on needle jumps to 3500 rpm engine idle. AC off engine idle - rpm dipped for 2 seconds and then back up to 3500 rpm. I have never had the fan problem until the tachometer problem started, so I'm inclined to think the there is a ground or short problem within the same circuit? The manual says that a code 42 is usually caused when the ECM shows voltage problems within the ignition system (distributor, coil, ignition module). Does this system regulate the tachometer and the secondary fans or do I have 2 separate problems?
Any assistance would greatly be appreciated. The next step in the manual calls for removing the ECM connections with a special tool that I do not have and probing the connectors with a multimeter and test light- both that I do have. I don't feel comfortable removing the ECM connectors without this special tool, as according to the manual, alot of damage can arise from using anything but this tool.
Is the a different route you would take to fix these problems? I am a novice at best and I really don't feel comfortable working on cars but unfortunately I do so out of necessity and not by choice. Again any tips, theories, or direction would greatly be appreciated.
Thank You
Dec 1, 2015 at 5:42 PM
RIVERMIKERAT
  • 6,110 POSTS
The tach is part of the engine control and ignition systems.
I need more info though to more accurately look your car up. Is it a base Vette or....? What trans does it have? Not sure it will make a difference in anything, but coupe or convertible?
Dec 1, 2015 at 6:57 PM
C4TONEZONE
The car is a 1990 Chevy Corvette - Base Model
Transmission is automatic
Body style is Coupe
motor - L98 - 5.7L 350
Dec 1, 2015 at 7:44 PM
RIVERMIKERAT
  • 6,110 POSTS
I'm not sure if the exact trans model makes a difference, but I'm going to presume it's got the 700R4 since it was the most prevalent.
I'm looking at a service bulletin that says that Code 42 could be caused by oil in the distributor cap.
My other thought before reading that was that it sounds like a loose ground caused by the bang in the pothole.
The fan issue sounds like a bad ECM. The schematics I'm looking at show the ECM in the loop for turning them on and off and being the only thing I can think of that clearing error codes would affect.
Dec 3, 2015 at 7:31 AM
