Taillight sensor affecting transmission shifting?
2019 NISSAN SENTRA
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
KGORDON19
I have been having problems with my transmission slipping when shifting from a stop to 1st gear. I took it to the dealer and was told that the problem is rainwater getting into a broken taillight and causing the sensor to detect the brake pedal has been applied. I have my doubts and want to double check.
Feb 19, 2024 at 8:24 AM
This car has the CVT transmission which they have had problems with. Can I ask if you hear any strange sounds coming from it? Also, do you have the check engine light on? If so, let's run the codes to see if any are stored.
I don't see the brake light having a sensor for the bulb out warning but it does report to the BCM. I don't think that would affect the transmission, but you never know. I would service the transmission and filter while checking the condition of the old fluid (burnt). Here is how the job is done so you can see what needs to be done.
Feb 19, 2024 at 9:58 AM
KGORDON19
I'm not getting any strange noises, only the rumbling sound you get when the transmission is slipping. No check engine light either. My transmission is covered under warranty, but Nissan is telling me it's not my transmission, it's a faulty sensor. However, my car is not accidentally braking, it's slipping during acceleration. Nissan's explanation doesn't make sense to me, and it seems like they are trying to get me to pay for something else, so they won't have to fix my transmission for free. I've attached a copy of the service receipt so you can see what they say.
Feb 19, 2024 at 10:06 AM
Yep, is the TCM is detecting the brake light being on it might cause a problem, but the noise will not. This sounds like the CVT belt has gone bad which is typical. Why can't we just fix the lens with a used one which wouldn't cost much to alleviate the problem, all you need to do it plug it in to see if the problem goes away, you can get one from Ebay. But my feelings are you are correct, they don't want to fix it for free. Sometimes and need it play the game to get them to fix it. Did you ask them why the transmission is making noise? Because this should never happen.
Feb 19, 2024 at 10:38 AM
