TCM location?
2011 CHEVROLET MALIBU
143,117 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LIZB2986
My Malibu feels like it doesnt want to go in gear when drving. Once i do get it in and out of 1st gear she drives fine, that is until I have to come to a stop or drive up a hill. My OBD II is popping the codes listed in the attatched image. Service ESQ message is also displyed on the dash. Ive checked all fuses they were all good.
Im hoping I can check the wiring and connectors in the TCM before spemding a few hundred replacing it.
However, I cant find any tutorials for my year, make and model. Can anyone tell me where the TCM is located? Any diagrams would be a plus.
Side note; it is a 6 speed.
Aug 20, 2025 at 9:07 PM
I don't see the images can you please reload it? I can help you more if I knew the code numbers, the TCM is located inside the transmission at the valve body, here is the location inside the unit in the images below.
Aug 21, 2025 at 7:42 AM
LIZB2986
Im not sure why the images wont upload. My posts says there are images but i cant see them i willl add the codes here. TCM location is exactly where i was dreading it woukd be. Thank you for the diagram.
P0601-00 Control Module Read Only Memory (ROM) Transmission Control Module (TCM)
P0700-00 Malfunction Indicator Lamp (MIL) Illumination 2036
2036 Description: Internal Electronic
Performance 2
1059 Description: Communication
Fault
3017 Description: Internal Electronic
Performance 1
1053 Description: Preload Failure
Region 2
Aug 21, 2025 at 10:53 AM
Essentially, the TCM is failing its own self-test. It’s not about sensors or wiring in most cases it points to an internal TCM fault, clear the codes once the job is completed.
Aug 21, 2025 at 6:57 PM
