Installed independent temperature gauge temperature readings
2009 NISSAN WINGROAD
385,900 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
KENNETH BALKARAN
I installed an independent temperature gauge and it was reading 90 then it went up to 110 degrees. is that normal or do I need to change my fans. note: the A/C was off.
Feb 3, 2020 at 4:25 PM
STEVE W.
  • 15,116 POSTS
Those numbers don't look bad. The 110 is about a normal fan cut on temperature these days. Did the temperature come down once the fans came on and they cycled on and off?
Feb 3, 2020 at 4:51 PM
KENNETH BALKARAN
Okay, thanks a lot for info. the 110 remained the same will have to monitor it some more.
Feb 3, 2020 at 5:02 PM
STEVE W.
  • 15,116 POSTS
Most modern engines tend to run hotter than what many people would think is normal. It isn't uncommon to see them run at a normal temperature of 105-110 with fans set to come on at those temperatures. I don't find a listed specification for the fan temperature in the information I have on that van. A call to a dealer may get you the numbers for it as built, however I wouldn't worry unless it starts showing as hot.
Feb 4, 2020 at 4:13 AM
