The heater, A/C fan, and cigarette lighter plug are not working?
2014 VOLKSWAGEN JETTA
65,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
VWGM369
  • 4 POSTS
Wife put e85 gas in the car and now the fab for air and heat plus cigarette plug no power plus high beam head light not working all other lights work fine and it drives and cranks with no problem. Not sure what fuse or relay controls any of these but I have checked all fuses under dash and the hood not sure about relays how to check.
Thank you
Oct 12, 2022 at 9:53 AM
There is a fuse #49 and fuse #30 on the left side of the dash fuse panel that needs to be checked for power. here is a guide to help you and the fuse location in the images below:
These fuses run the blower motor and the cigarette lighter power socket if neither have power and the fuses is okay, I would replace the terminal 75 power relay (relay #1 inside the 12-relay carrier). I don't think the e85 would cause this issue. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Oct 12, 2022 at 2:55 PM
VWGM369
  • 4 POSTS
Okay, I am not sure which ones I should replace. Is it from top number 1 left to right or bottom left to right as a am looking at it. Thank you so much for the help.
Oct 12, 2022 at 4:09 PM
VWGM369
  • 4 POSTS
The fuses all check out good. Also looks like a main power relay zip tied in that is on bottom right as looking at it.
Oct 12, 2022 at 4:13 PM
VWGM369
  • 4 POSTS
Here are a few pictures I tried taking:
Oct 12, 2022 at 4:21 PM
Thanks for the images, the location has been changes to relay # 10 which is second to the right on the bottom row.
Oct 13, 2022 at 2:05 PM
