Ticking sound in engine near the timing belt assembly?
2008 CHEVROLET AVEO
189,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RPJ
  • 97 POSTS
Hello.
On my vehicle listed above, I've noticed a ticking sound from the engine near the timing belt assembly. It's not constant, every few seconds or so, but goes away after a couple of minutes.
I hear this at start-up, but I have not noticed it when driving.
Any advice/help is appreciated.
I've attached a video so you can hear it.
Thanks,
Roosevelt.
Aug 19, 2025 at 6:33 PM
Hello Roosevelt,
Thanks for the video, it helps. this noise sounds like the timing belt tensioner bearing is going out. I would change the timing belt and tensioner to fix the problem. But to be sure I would remove the serpentine belt and start the engine to see if the noise is gone, if not do the timing belt job. Here are the timing belt marks to help you do the job. Check out the images (below). Please upload pictures or videos in your response so I can see the problem.
Aug 20, 2025 at 12:55 PM
RPJ
  • 97 POSTS
Thanks Ken,
I will have the car checked out and let you know what the diagnosis is.
I appreciate your help.
Roosevelt.
Aug 21, 2025 at 6:21 AM
Hello Roosevelt,
That would be great, I am interested in what you find.
, Ken
Aug 21, 2025 at 7:17 AM
RPJ
  • 97 POSTS
Hello Ken,
My mechanic checked the vehicle and said there was engine damage. They do not do internal engine repair at this shop, so I'm not sure where to go from here.
This is a 1.6L, 17y/o car and I'm not sure if it's worth fixing. There is nothing leaking from the engine and there are no lights on the dashboard. The car drives OK, but I wonder how long I will be able drive it.
Thanks,
Roosevelt.
Aug 25, 2025 at 7:15 PM
Did they check the timing belt? I would take it to a different shop for another opinion.
Aug 26, 2025 at 9:16 AM
RPJ
  • 97 POSTS
They didn't as far as I know. I think they just listened to it.
I can try another shop and let you know.
Thanks.
Aug 26, 2025 at 9:37 AM
Good call, let me know.
Aug 26, 2025 at 9:48 AM
RPJ
  • 97 POSTS
Hello Ken,
Took my car to another shop, and you were correct, bearings in the timing assembly were going bad. Thank goodness it didn't fail.
Car is repaired and running fine. Thanks for your advice. I do wonder why the shop I normally use did not detect that.
But anyway, everything's good for now.
Thanks again for your help.
Roosevelt.
Sep 14, 2025 at 6:41 PM
Yep, sometimes mechanics just miss problem, it is good to have another set of eyes on it :) use 2CarPros anytime we are here to help.
Sep 15, 2025 at 7:56 AM
