How to remove and replace Tie rod?
2006 CADILLAC SRX
173,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
RAMPRATS6030
  • 16 POSTS
I need a complete removal and replacement tie rod guide for the inner and outer. I’m confused. I’ve read in some spots that say you can replace the inner tire rod some say you can’t without replacing the rack and pinion and I can’t seem to find any service manuals I even joined all data DIY that was absolutely zero help. All the manuals seem to be here for either a different make and model or the parts aren’t the same.
Mar 14, 2023 at 12:07 PM
Yep, they only show the outer tie rod being replaced and don't say anything about the inner the outer tie rod replacement instructions are below for clarification. Check out the images (below). I wish we could be more help; I will ask other experts to join in to see if they can contribute.
Mar 15, 2023 at 11:38 AM
WRENCHTECH
  • 20,761 POSTS
They don't even sell an inner for that vehicle. It may be non-serviceable. It appears Moog makes one and World Pac seems to be the only one that carries it.
Mar 15, 2023 at 12:59 PM
STEVE W.
  • 15,113 POSTS
I looked at GM service info and they don't show the process, there are a number of inner ends available Moog, Delphi, TRW, Mevotech being a few. However even the OE service info doesn't show the inner tie rod changes. Strange because they are not anything special, the boot comes off and the end unscrews. The same style rod end and boot are used on the Trailblazer and it's siblings and that has the info for it's replacement. However they do say to remove the rack first. I suspect it's typical GM BS to make the Caddy crew pay more.
Mar 15, 2023 at 5:54 PM
WRENCHTECH
  • 20,761 POSTS
Maybe there's something in the design of the rack that can't handle the torque of removing and replacing it.
RAMPRATS6030
  • 16 POSTS
I stumbled on something stating the rack and pinion and inner tire rods couldn’t be serviced separately, but that just doesn’t make any sense, but the end of my outer tie rods doesn’t have a jam nut right at this end of it. It’s up at the boot near the top of the inner tire rod, so maybe there’s something strange about that. But on car parts, I ordered an inner and outer tie rod kit and there’s says they’re guaranteed to fit but I absolutely can’t find any procedure on it.
Mar 15, 2023 at 11:06 PM
RAMPRATS6030
  • 16 POSTS
Thank you for all your input. I really appreciate it cause I’m just a girl that has found a need for knowledge of mechanics. And ability so mostly self-thought and this Cadillac little more advanced computer and features wise then I really care for just because my ole 71 c10 pretty self-explanatory ish lol Cadillac not so much this one was rear ended and apparently took it kind of hard someone mentioned I’d be a fool not to replace the rack n pinon bc they said if the tie rods were bent then it destroyed the rack but idk because I think that’s where there’s supposed to structure failure in case of severe impact , so it don’t destroy everything , not saying it couldn’t or wouldn’t it’s just this SRX really didn’t look to be insanely wrecked just slammed in the left corner enough it piled the bumper structure lose.
Mar 15, 2023 at 11:13 PM
RAMPRATS6030
  • 16 POSTS
I ordered a set of car parts .com there tqr I beliveI stumbled on something stating the rack and pinion and inner tire rods couldn’t be serviced separately, but that just don’t make any sense but the end of my outer tie rods doesn’t have a gym nut right at this end of it. It’s up at the boot near the top of the inner tire rod, so maybe there’s something strange about that. But on car parts, I ordered a inner and outer tie rod kit and there’s says they’re guaranteed to fit but I absolutely can’t find any procedure on it.
Mar 15, 2023 at 11:21 PM
No problem, we are here to help. Please let us know what happens.
Mar 16, 2023 at 10:59 AM
RAMPRATS6030
  • 16 POSTS
Okay. so, I’ve removed the outer tire rod now coming to the inner tire rod. There is some kind of a weird plastic thing. It’s directly behind the inner tire rod and it looks like there’s something possibly plastic up in the steering gear rack. Is that supposed to be there?
Mar 22, 2023 at 2:31 PM
RAMPRATS6030
  • 16 POSTS
Here’s a little better idea of what’s going on or is the question at hand … does the yellowish plastic piece belong and up inside the steering rack gear and appears to be something plastic? Is that supposed to be there? The replacement inner tie rods did not come with no plastic thingy, lol.
Mar 22, 2023 at 2:33 PM
CARADIODOC
  • 34,308 POSTS
Hi there my fine feathered friends. I can add another dimension to this story. I ran into this same issue at the Chrysler dealership. The reason the inner tie rod procedure is not listed in the service manual is it was not intended to be replaced in the field when the vehicle was still under warranty. I never ran into a bad one in warranty, but if I had, we were supplied with a brand new rack and pinion assembly with both inner tie rod ends and both outer tie rod ends already installed. I did replace a few rack assemblies on the Stratus model for a very slight chirp when changing direction. Those were covered under warranty and a service bulletin for "customer satisfaction". Those racks also came with all four new tie rod ends.
Part of their warranty policy had to do with anything that was replaced under warranty had to restore that system to like new condition. That meant no used or rebuilt parts, and no machining of parts like brake rotors because that would reduce their life expectancy.
They never said the inner tie rods couldn't be replaced separately, but they left that up to the aftermarket suppliers. You might still find torque specs in the service manual, but always defer to those listed on the instruction sheet that comes with the new part.
The plastic piece described is often referred to as a "cushion". It slides over the end by my red arrow in the first photo. It softens the metal-to-metal contact when the steering system is turned fully in that direction. Tap that off with a flat-blade screwdriver and small hammer. You can reuse it if it fits. New inner tie rod ends sometimes come with a plastic disc that is slid on first for the same purpose. Don't use both.
The tool to remove this design is shown in the second photo. Use the crow's foot that fits the two flats on the back side of the joint. Slide the tube over it and run the ears into the two slots on the tool. Swivel the metal ring to hold the wrench in place. Put just a little outward pressure on the tool to keep the wrench on the flats while turning it with a ratchet.
Buy this tool from any auto parts store or any of the tool trucks that show up each week at the repair shops. You can also rent or borrow it from auto parts stores that borrow tools. In my city they make you buy it, then you get a full refund when you take it back. If you choose to keep a tool, you still return it, then they give or order you a brand new one.
By the way, three of my best students were girls. (I think they still are). The guys had a lot of respect for them.
Mar 23, 2023 at 5:53 PM
RAMPRATS6030
  • 16 POSTS
Thank you so much. So I might’ve cranked the driver side down a little bit much on the inner tire rod I done it says 62 pounds foot pressure but that kind of shaved a little bit of that plastic cushion you know not much I just peeled back a little bit. I guess it is the closest side to the rack. My replacement parts from carpros.com were supposed to include a flat metal washer with the tabs you’ve been down which they seem to forget that my shipment and my new jam nuts that I can’t seem to find any parts store or warehouse. Also, that plastic cushion on the driver's side did not move freely. I can only move it about a quarter of an inch away from the inner tire rod on the passenger side. It moves freely back-and-forth down the shaft and neither one had the metal tabbed washer. those need to be on there don’t they buy videos I’ve watched I’m saying yes for sure it does but then again I’m pretty sure these tie rods Hartman replaced unless somebody was pretty anal about the metal clamps and stuff like that being exact which is possible very possible so I’m thinking it might’ve came from the factory without those in there but then again, the replacement parts were supposed to have them in there and did not end up inside of like the rack. I can see another like same color, yellow plastic I’ve been there like maybe something broke I’m not quite sure It could be normal. There wasn’t much Fluid inside of the Bello boot whenever I took it apart, I mean, there was some, but not a gaping, a mound or nothing like that I’d say a hefty teaspoon or two worth I will attach some pictures that I took. I’m fixing to go out there and examine the passenger side some more. It was right before dark when I got the driver side together yesterday and got the passenger side off there. I didn’t even look inside the Bello boot. I just popped off the clamps and took it off and seen that plastic piece was free, moving and thought oh man, nothing can ever be the same or match lol. Any input would be much appreciated. I really appreciate your thoughts and your knowledge. I really do because I really don’t have anybody I can turn to, for any kind of mechanical advice.
Mar 26, 2023 at 8:26 AM
RAMPRATS6030
  • 16 POSTS
Thank you so much OK so I might’ve cranked the driver side down a little bit much on the inner tire rod I done it says 62 pounds foot pressure but that kind of shaved a little bit of that plastic cushion you know not much I just peeled back a little bit. I guess it be the closest side to the rack. My replacement parts from carpros.com was supposed to include a flat metal washer with the tabs you’ve been down which they seem to forget that my shipment and my new jam nuts that I can’t seem to find any parts store or warehouse. also, that plastic cushion on the driver side did not move freely. I can only move it about a quarter of an inch away from the inner tire rod on the passenger side. It moves freely back-and-forth down the shaft and neither one had the metal tabbed washer. those need to be on there don’t they buy videos I’ve watched I’m saying yes for sure it does but then again I’m pretty sure these tierods Hartman replaced unless somebody was pretty anal about the metal clamps and stuff like that being exact which is possible very possible so I’m thinking it might’ve came from the factory without those in there but then again, the replacement parts were supposed to have them in there and did not end up inside of like the rack. I can see another like same color, yellow plastic I’ve been there like maybe something broke I’m not quite sure It could be normal. There wasn’t much Fluid inside of the Bello boot whenever I took it apart, I mean, there was some, but not a gaping, a mound or nothing like that I’d say a hefty teaspoon or two worth I will attach some pictures that I took. I’m fixing to go out there and examine the passenger side some more. it was right before dark when I got the driver side together yesterday and got the passenger side off there. I didn’t even look inside the Bello boot. I just popped off the clamps and took it off and seen that plastic piece was free, moving and thought oh man, nothing can ever be the same or match lol. Any input would be so appreciated. I really appreciate your thoughts and your knowledge I really do because I really don’t have anybody I can turn to, for any kind of mechanical advice.
RAMPRATS6030
  • 16 POSTS
Bellow boot driver side.
Mar 26, 2023 at 8:28 AM
RAMPRATS6030
  • 16 POSTS
Mystery plastic piece inside rack.
Mar 26, 2023 at 8:29 AM
CARADIODOC
  • 34,308 POSTS
I got confused reading those really long sentences, but it sounds like lack of experience is the only concern. From what I can see in the photos, it looks like there is some grease or assembly lube in the boot. That can be ignored. If you have power steering fluid that can be poured out, it's time to replace the entire steering gear assembly. With a seal that just recently started to leak, you might find a good half quart of fluid in that one boot. When one seal has been leaking for some time, that boot will fill up, then it will travel to and fill the other boot through the small metal air transfer tube plugged into each boot. At that point there's no way to tell which seal or if both are leaking. Just replace the assembly and let the rebuilder worry about finding and correcting the cause.
I have seen a few places where you can buy seal kits, but repairing these is something we don't do. Years ago a new rack and pinion assembly used to cost around $450.00. You only got a brand new one if the vehicle was under warranty, and then the customer didn't pay for it. As far back as the late '90s, you could buy a professionally-rebuilt rack and pinion assembly with a warranty for less than $150.00. That's a much better value than removing and trying to rebuild an old steering gear yourself. You'll miss or overlook something and end up doing the job a second or third time. Rebuilt rack and pinion assemblies also correct a design flaw that was very common on older GM vehicles.
When you have a thin steel plate with tabs to bend over, those are designed to prevent the part from loosening and unscrewing on its own over time. In this case, the center hole would fit onto the end of the steering gear's shaft only one way so it couldn't rotate, then, once the inner tie rod is screwed on and torqued, the tabs on that plate are bent over the socket of the joint to hold it from turning. Other methods that have been used include an Allen-head set screw and Loc Tite liquid on the threads. Some older designs, mostly on Ford products, used a pressed-in roll pin. Those were supposed to catch on the threads, but only after the tie rod had already unscrewed part way. A special tool was needed to pull those out, but you could easily get them out just by unscrewing the tie rod end. The threads would push those pins out without damaging the threads.
Mar 27, 2023 at 3:15 PM
