What are the timing chain replacement hours?
2013 CHEVROLET EQUINOX
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
STUARTHARDEE
Amount of time for an experienced DIY mechanic to replace timing chains, guides and water pump in this engine? Engine is still running fine at this point, just getting noisy.
Jun 20, 2024 at 4:58 AM
The water pump should be included since it needs to be removed to do the timing chains. Here are the labor times for the timing chains and guides.
Timing Chain, R&R 7.0 HRS @ shop rate
NOTE (Optional Labor) To R&R Chain Guides, Add Each 0.1 HRS @ shop rate
To R&R Chain Tensioner,Add 0.1 HRS @ shop rate
To R&R Crankshaft Gear, Add 0.2 HRS @ shop rate
Let us know if you need anything else.
Jun 20, 2024 at 9:38 AM
