TIMING CHAIN COVER TORQUE SPEC
2013 CHEVROLET CRUZE
123,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1
  • 102 POSTS
Just finished the timing chain replacement. I installed the cover with some silicone on where the metal splits. Just need the spec for the cover bolts. Please don't tell me that shorter and longer ones have different spec lol. Also need the same for the water pump bolts and the valve cover bolts please.
Jan 15, 2026 at 5:41 PM
STEVE W.
  • 15,113 POSTS
These should cover all the bolts and nuts you need. Oh and sorry but the bolts have different specs... The 2 larger bolts are M10. the other 13 are M8 spec
Jan 15, 2026 at 8:11 PM
DIVIDES
  • 903 POSTS
Thanks. Oh ya I knew there are 2 big bolts, just meant that the smaller ones have different length, and didn't know if some are different than the other small ones in torque.
Jan 16, 2026 at 5:12 AM
STEVE W.
  • 15,113 POSTS
No difference with those, as long as they are in the correct holes. Don't want a long bolt in a short bolt hole.
Jan 16, 2026 at 7:11 AM
BHAMDOC1
  • 102 POSTS
True. Thanks
Jan 16, 2026 at 7:41 AM
STEVE W. is one of our best! Use 2CarPros anytime, we are here to help.
Jan 17, 2026 at 9:16 AM
