Timing chain job
2007 FORD F-150
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
AGILL
  • 5 POSTS
I’m doing a timing chain replacement on a 2007 5.4l, I have all the roller followers out and I have installed the new chains, phasers, guides and tensioners. Is it ok to go ahead and turn the crankshaft to get the cams in the right position to put the roller followers back in, since the chains are all right on the phasers will it keep the correct timing if I turn the crankshaft to put the followers back in . I used the tool to get the crankshaft in the correct spot to set timing to put the chains on but I know it won’t be in that spot after turning it to get all the roller followers back in
Thanks
Aug 3, 2025 at 4:28 PM
Yes, it is okay to rotate the engine over without bending the valves, you must adhere to these videos to show you how and what to do. It is best to keep all of the roller followers out while installing the timing chains.
https://youtu.be/dler2t2e4Zw?si=TJhXS2pnr4xk9jcL
and
https://youtu.be/XRdG1ZEUSAc?si=lkTkMFwuLAXNUQ8n
Let us know if you need anything else.
Aug 4, 2025 at 12:30 PM
AGILL
  • 5 POSTS
Ok so when I turn the crank to get all the followers back in I don’t have to worry about putting it back in a certain spot, it’s good to go as long as all my marks were lined up correct
Aug 4, 2025 at 6:07 PM
That is correct, remember once you turn the engine over after the timing marks were lined up they wont line up again when rotating the engine over FYI.
Aug 4, 2025 at 6:09 PM
AGILL
  • 5 POSTS
Ok thank you sir
Aug 4, 2025 at 6:35 PM
You are welcome, let us know if you need anything else.
Aug 5, 2025 at 8:27 AM
AGILL
  • 5 POSTS
One more question. I have all my roller followers back in. I know my marks are not lined up now since I had to turn the crank several times. Do I need to turn the crank to line the pulley notch up with tdc or can I just put the pulley on where it sits now
Aug 5, 2025 at 4:41 PM
You can just install the damper. There is only one way it goes on.
Aug 5, 2025 at 5:54 PM
AGILL
  • 5 POSTS
Well, got everything back together and trucks starts fine with no issues and sounds good, better than before. Will run fine until it gets hot then it runs rough like it’s missing. No check engine light comes on. I plugged my scan tool up anyway and it reads p0300. Ever seen this. Where should I start.
Aug 14, 2025 at 5:20 PM
Nice work, I would clear the codes and drive it, this might be a residual issue and it might work it way out, if the code comes back please start a new thread. we only handle one problem per thread, please post your new question here, you must be logged in.
Thanks for letting us know. Cheers, Ken
Aug 15, 2025 at 11:50 AM
