How to remove and replace the timing chain?
2018 FORD F-150
187,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
GEORGESCHOBER
What is the procedure for removing the old timing chains, and then the procedure to put the new ones back on.,
Mar 7, 2025 at 1:33 PM
This is a big job, but very common on these engines. You will need to replace the camshaft actuators, guides and tensioners as well. This video will give you an idea of what needs to be done, and I have included instructions for your truck in the images below.
https://www.youtube.com/watch?v=dler2t2e4Zw&t
Start draining the coolant and disconnecting the battery, then remove the timing cover. Here is what you do after that. I would also make sure the camshaft actuator oil control valves are clean and working as well. Here are their locations. Check out the images (below).
Mar 8, 2025 at 10:44 AM
GEORGESCHOBER
Thank you for all this information. I'm waiting for my parts to come in and then I will install them. I will let you know how it went and any other questions I might have. Thank you again!
Mar 8, 2025 at 12:11 PM
Sounds good, we are here for ya!
Mar 10, 2025 at 8:41 AM
