Timing solenoids, sensors, and chain?
2007 SATURN SKY
50,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KARL HUNGUS
My vehicle listed above was sluggish, had trouble changing gears, and a rough idle. Basically, no power. Higher mileage engines have a notorious timing chain guide problem, but mine is well below the range for that. I changed the VVT solenoid first. The old solenoid were clean and showed no evidence of metal from the chain in the mesh. I drove it a short way after the change but still have the issue. Is there a reset of sensors or anything to do after changing the solenoids?
Jul 31, 2025 at 5:12 PM
No there is nothing to reset. What codes are you getting? Please list them here. Go over this guide to help
You may have a bad MAF or a clogged catalytic converter. The engine has 50k on it correct? Please go over this guide and get back to us.
Aug 1, 2025 at 12:31 PM
