Recently my 4runner overheated. After stopping to allow it to cool I filled it with water and coolant only to discover a considerable amount leaking out the bottom. I can't see exactly where it is leaking from due to the skid plate. It continues to leak and overheat. I fill it with water everyday before heading out and luckily only have to drive a few miles. However it always overheats in just that short time. Also the heat does not work. I also experience an almost stall when the vehicle is cold and I press the gas to take off from a stopped position. As soon as I release the pedal the engine returns to idle speed with no apparent problem. If I allow the idle to get it moving and slowly press the pedal it sputters a bit but doesn't stall. Once It's warmer the problem disappears.
Jun 16, 2008 at 2:31 PM
