1997 Toyota 4Runner replacing fan blade on 1997 toyota 4run
1997 TOYOTA 4RUNNER
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
DACH2001
MEMBER
1 POST
FOLLOW
Is this a job that can be done without taking the car to a mechanic
If so, please advise procedure
Thanks
D
Nov 7, 2010 at 8:36 AM
KHLOW2008
CERTIFIED EXPERT
Hi dach2001,
Replacing the clutch fan is not a very difficult job.
Loosen the 4 nuts holding the clutch fan.
Loosen alternator drive belt.
Remove the clutch fan holding nuts and fan can be removed.
If radiator fan shroud is hampering work, remove it by unclipping the lower shroud and removing the holding bolts for the main shroud. Upper radiator hose has to be removed.
