1998 Toyota Camry Camry 1998 Low Oil Pressure Warning Light
1998 TOYOTA CAMRY
LORDM
Engine Mechanical problem
1998 Toyota Camry 4 cyl Automatic 149000 miles
I have a toyota camry with 149K miles on it. I recently bought this car and have limited knowledge about it. Now when i keep the key in the ON position (just before cranking the engine) the following lights on the dashboard light up and stay
1. battery light
2. Low Oil Pressure Warning Light
3. Check engine light.
The ABS light is on for a few seconds and then goes off.
Now when I crank the engine only the check engine light is still on and the other two lights are off. Does this indicate problem with the oil pressure and battery? Also since the engine check light is on.. what is the likely reason for it?
Sep 14, 2008 at 5:19 PM
BMRFIXIT
  • 19,053 POSTS
Key on engine off you should have all lights on
engine running all light off normal operation
check engine light you need to have it scanned for codes
Sep 14, 2008 at 5:48 PM
