2004 Toyota Camry BRAKE PEDAL LOW
2004 TOYOTA CAMRY
50,000 MILES • 4 CYL • FWD • AUTOMATIC
DDNN99
Hi!
My 2004 Camry got brake problem and no repair shop can fix the problem. The brake pedal is low (almost to the floor) when I press the pedal... I already changed brand new master cylinder, new brake pads and shoes and also bleed the brake... but the problem is still the same, I brought my car to 3 different shops and all of them said the master cylider no good, then they change another new master cylinder but the problem still the same. I know the master cylinder is not the problem as I already changed couple times, they also checked other parts relate to the brake but no one can find anything wrong.
Please give me some advices what else can be wrong with my car so I can fix the brake.
Thank you very much for your time to help me.
Danny Nguyen
[email protected]
Nov 27, 2008 at 8:17 PM
Have you physically checked the wheel cylinders for leakage that's if it has a drum type brake-Does it have an ABS ?
Nov 27, 2008 at 8:22 PM
